Community Member
Intermittent wireless connection with 2 SSIDs
I have been trying to set up an 877W with 2 SSIDs, one encrypted with WPA using the local radius server and the second completely open to allow guests Internet access.
Both the encrypted client and the open clients can connect and browse the internet, but the wireless connection to both is extremely intermittent, with pings to the 877W being regularly dropped.
Config is below, i would be extremely grateful for any feedback anybody could provide. Thanks in advance,
Chris
aaa group server radius rad_eap
server 172.20.22.1 auth-port 1812 acct-port 1813
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login local_authen local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods2 group rad_eap2
aaa authentication login eap_methods1 group rad_eap1
aaa authorization exec local_author local
aaa authorization ipmobile default group rad_pmip
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
interface Dot11Radio0
description $FW_INSIDE$
ip address 172.20.22.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
encryption vlan 4 mode ciphers tkip
ssid $ySC0m^^
vlan 4
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa
ssid syscomm
vlan 2
authentication open
guest-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
l2-filter bridge-group-acl
no cdp enable
interface Dot11Radio0.2
encapsulation dot1Q 2
ip address 172.20.23.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no cdp enable
interface Dot11Radio0.4
encapsulation dot1Q 4
ip address 172.20.24.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no cdp enable
interface Vlan1
ip address 172.20.21.1 255.255.255.0
ip access-group 104 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
ip policy route-map CLEAR_DF
hold-queue 100 out
interface Dialer0
bandwidth 256
ip address negotiated
ip access-group 102 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip inspect SDM_LOW out
ip nat outside
encapsulation ppp
ip route-cache flow
ip tcp header-compression
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname
ppp chap password
ppp ipcp dns request
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http access-class 1
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list nat1 interface Dialer0 overload
ip access-list extended nat1
permit ip 172.x.x.0 0.0.0.255 any
radius-server local
nas 172.20.22.1 key xxx
group fast
user syscomm
user david
radius-server attribute 32 include-in-access-req format %h
radius-server host 172.20.22.1 auth-port 1812 acct-port 1813 key xxx
radius-server vsa send accounting
289
