Interpreting the Carrier test on a 350 Bridge
What are acceptable values for the "Carrier Busy" and "Noise Value" when performing the carrier test on a 350 bridge?
For Carrier Busy, I'm getting 10% max across all channels
For Noise Value, I'm getting -83dBm max across all channels
  • Other Wireless - Mobility Subjects
Re: Interpreting the Carrier test on a 350 Bridge
The carrier test measures the amount of radio activity on each frequency available to the bridge. Use the carrier test to determine the best frequency for the bridge to use. You need to use the lowest busy and lowest noisy channel..So pick one like that.
When you conduct a carrier test, make sure all wireless networking devices within range of the bridge are operating to make the test results reflect a realistic radio environment.
Does -83dbm mean that the air is clear or dirty. Is there a breakdown of poor | fair | good | excellent as with the pc card site survey tool. What would be a poor dbm number? fair? good? excellent?
Dan
If you see noise that high and busy carriers across all channels, you have a difficult environment. -83 means that without external antennas, you have little hope of getting clients to connect reliably (A noiseless environment would be -100dBm, the 17dB difference is logarythmic - 500% more noise than -83).
Your useable signal will be total signal minus noise, so armed with that you can figure your required antenna gain to reach a stated distance.
Matthew Wheeler
Chief Wireless Architect
Blue Modal, Inc.
http://www.bluemodal.com
Anonymous
N/A
I have the same question, I installed a pair of 350 bridges, and the distance of 13 km between ech other, and I don´t know what is the right (dbm) in the antenna alignment test, for that king of link.(Data rates are 11Mbps,5.5,2, and 1)
128
