Intersil PRISM Wireless LAN PCI Card and Cisco Aironet!!
I do have a lifebook (Fujitsu) with the an intergrated Intersil PRISM card. Is this compartible, or how can I get it to work with my Cisco Aironet WLAN? Thanks for the help!!
Silver
Re: Intersil PRISM Wireless LAN PCI Card and Cisco Aironet!!
If the PRISM wireless PCI card is 802.11b Wi-Fi compliant, then there will not be any interoperability issues. Check if you can find the Intersil PRISM Wireless LAN PCI Card here:
http://www.wirelessethernet.org/OpenSection/index.asp
Thank you for the input. I do have the cisco 350 series PCMCIA card installed now. I was looking for some kind of a plug-in that I can apply to the existing PRISM client utility.
398
