IOS AP Password Recovery
Hi All,
Does anyone know how to recover the username/password whilst keeping the existing config and not defaulting the AP.
Re: IOS AP Password Recovery
According to this link it isn't possible:
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_password_recovery09186a00800949d0.shtml
It makes sense as AP's don't support the "config-register" command, which is the usual (router) method of password recovery.
Andrew.
Thanks Andrew,
That's what I thought but I was hoping that someone might have known a non-documented way.
The AP has a Cat 2900 style bootloader, not a
router style rommon. So you don't get
config-register; however you do have similar
functionality. See http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2970/12218se/2970cr/bootldr.htm
for (fairly close) documentation.
To do password recovery on an IOS AP, without
losing your config, do something like this:
1. Connect to the console
2. Power cycle the AP (or otherwise induce it to reload)
3. Hit on the console real fast, a couple of times
4. Get to the bootloader ("ap:") prompt
5. Now rename the config.txt file to something else (ap: rename flash:config.txt flash:config.foo)
6. Now continue booting
7. The old config will be in flash:config.txt
Should work, although it may not, depending on the bootloader version.
178
