IOS command i/f for IP information
New to the world of IOS. What is the commands sequence to configure an AP's IP address, Subnet mask and Default gateway.
Assume that I will be starting from AP>
1 ACCEPTED SOLUTION
Re: IOS command i/f for IP information
at ap> type the following sequence. Press enter at the end of each line.
en
Cisco
conf t
ip default-g g.g.g.g
int bvi1
ip add x.x.x.x m.m.m.m
end
cop run st
After you type en and Cisco, the prompt will change to ap#.
After typing conf t, the prompt will change to ap(config)#
After int bvi1, the prompt will change to ap(config-if)#
g.g.g.g is the default gateway address
x.x.x.x is the IP address you would like to assign to this AP.
m.m.m.m is the network mask.
cop run st copies the running config, which you just modified, to the startup config. Rebooting without this command will revert back to the previously saved settings.
There is a ton of IOS documentation the Cisco web site.
Hope this helps.
1 REPLY
en
Cisco
conf t
int bvi1
end
cop run st
Hope this helps.
174
