Community Member
IOS on 1200 APs (NOT)
We bought a large batch of 1200 APs (1220b) soon after they were released in North America. Since the past winter, we have been hearing that IOS was coming to the APs as an upgrade. Now that it is here, we come to find out that IOS will only be supported from the factory and that 1220b's will never be supported. Not only that, but I predict that all development on the current firmware will be stopped and resources moved to IOS. That leaves those with 'original' 1200 series APs with a sub-supported product. I was wondering if anyone else had any information on this recent change. We bought these APs for their upgradability and future support, but it now seems that there has been a product change mid-series that renders the older APs obsolete less any security updates. Is this true? Can someone here shed some light on the situation please?
Community Member
Re: IOS on 1200 APs (NOT)
IOS code for the original 1220's is currently in beta and is scheduled to be available in June.
Community Member
Thank you for the info...
Community Member
karey,
are you sure about this. do you have an email or documentation for this?
thanks!
jason
Bronze
The IOS code can now be downloaded from CCO along with an upgrade utility. You need the 12.2(11)-JA version of IOS. Make sure you get the helper (conversion) image, not the regular IOS image.
152
