Community Member
IP Forwarding Agent / DHCP Client, Virtual IP Router
I have a problem with some of my clients. They have static IP's but attach to the AP350 with address 0.0.0.0 and with : "OK, WEP, IP Forwarding Agent, BOOTP/DHCP Client, IP Virtual Router." in the Status cell.
What would cause this?
Thanks.
1 REPLY
Community Member
Re: IP Forwarding Agent / DHCP Client, Virtual IP Router
Can you check if you have enabled Broadcast key rotation. When you enable broadcast key rotation, only wireless client devices using LEAP or EAP-TLS authentication can use the access point. Client devices using static WEP (with open, shared key, or EAP-MD5 authentication) cannot use the access point when you enable broadcast key rotation. This may be the reason for your problem.
319
