IPAD NOT CONNECTING TO AP 1142
abukuru95
Level 3
Level 3
Hello Guys, I have an ipad that is not able to connect to a 1142 Autonomous AP. This AP was originally a light weight AP and then downgraded to autonomous.A strange thing i see is that the AP shows me only two radios. 802.11 N(2.4 GHZ) and 802.11 N(5 GHZ). I suspected the AP not to support the b/g networks. i then downloaded the most recent software but i still cannot get it to connect and on the AP's GUI i only see the above two mentionned radios. i tried to connect to two SSID's. one using WPA2 and another with open authentication and no security.but this does not work. Is it possible that some 1142 do not support b/g networks?
any help is highly appreiated.
21 Replies 21
Scott,
Thanks, I will double check but I believe that's what it was set to, and I have also tried both 10 and 75 per recommendations on another thread.
Brian
That is pretty high.... default is at 1 and usuallly can be set to 2 with no issues.
-Scott
Scott thanks for your help.  After talking with Cisco yesterday and also taking your DTIM recommentation into consideration, my radio settings are:
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 2 mode ciphers aes-ccm
encryption vlan 3 mode ciphers aes-ccm
ssid Guest
ssid Internal
antenna gain 0
mbssid
station-role root
beacon dtim-period 1
no dot11 extension aironet
Argh...any other ideas?
Brian
I saw sometimes problem with hidden SSIDs I didn't see in the config that you broadcast your SSID. With that command
mbssid guest-mode dtim-period 75
you broadcast your ssid, just give them a try maybe.
regards,
Sebastian
Thanks Sebastian.  Both SSIDs for the two VLANs are broadcast.
Brian
Did you ever get it to work?  If so what was the solution to your issue?  I am having a similar issue.
jwinters99,
For me, my issue was the device handing out DHCP.  For my network it was served out by the Watchguard, and as I wrote above, iDevices (as well as Androids and most laptops) would never get an address properly, but DID work if I set them static.  So, we chalked it up to a Watchguard thing, because as soon as we yanked the DHCP role off the WG and put it on our core switch, ALL the devices started working correctly immediately.
Brian
