IPAD NOT CONNECTING TO AP 1142
abukuru95
Level 3
Level 3
Hello Guys, I have an ipad that is not able to connect to a 1142 Autonomous AP. This AP was originally a light weight AP and then downgraded to autonomous.A strange thing i see is that the AP shows me only two radios. 802.11 N(2.4 GHZ) and 802.11 N(5 GHZ). I suspected the AP not to support the b/g networks. i then downloaded the most recent software but i still cannot get it to connect and on the AP's GUI i only see the above two mentionned radios. i tried to connect to two SSID's. one using WPA2 and another with open authentication and no security.but this does not work. Is it possible that some 1142 do not support b/g networks?
any help is highly appreiated.
fb_webuser
Level 6
Level 6
increase DTIM to 10 or 75 radio preamble to long and disable aironet extension
radio preamble long
Posted by WebUser Danny Borpatragohain
21 Replies 21
blakekrone
Level 4
Level 4
The 1142 does support b/g networks, it is simply labeled as 802.11 N.
We'll need more information about how you have the WLANs setup as well as the radios. Is this an iPad1 or 2?
hello blakerone,
it is an ipad2 with ios 5. i have two SSID's.one for guests open authentication and another with WPA2 preshared key. I have the latest IOS installed. client PC connect normally without any issues with full network and internet connectivity. but with the ipad, i get a message saying that is is trying to connect. no IP address is received, and in the debug messages on the AP, i see authenticatiion starting and failing.
Can you post the config of the AP?
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Hello Stephen
here it is;
version 12.4
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
logging buffered 65535 debugging
no logging console
no aaa new-model
clock timezone cet 1
clock summer-time cdt recurring last Sun Mar 2:00 last Sun Oct 3:00
dot11 syslog
dot11 ssid xtreme
   vlan 15
   authentication open
   authentication key-management wpa version 2
   wpa-psk ascii cisco990?
dot11 ssid xtreme-guest
   vlan 20
   authentication open
dot11 arp-cache
crypto pki trustpoint TP-self-signed-3172633717
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3172633717
revocation-check none
rsakeypair TP-self-signed-3172633717
crypto pki certificate chain TP-self-signed-3172633717
certificate self-signed 01
  30820244 308201AD A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33313732 36333337 3137301E 170D3032 30333031 30323139
  32335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 31373236
  33333731 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B341 FFA5D97C FF14DEEC 32689FAB AC8418ED 65138316 D6560275 23E25E77
  5A2AB2EF 4A9BC17C 098C0310 BF414FC6 CA201151 7D71E8A0 386402BA 055CE0B7
  8BE4E179 1ED5B1E8 F0DBB2EA 149A3AC2 72FC8373 FA976B76 79F85DE2 8D817E15
  5C7E6D33 E66AFF29 60DCD164 40F07CB9 6CE355EA 4C12BA29 63F6CBD8 CA7070E8
  4DB50203 010001A3 6C306A30 0F060355 1D130101 FF040530 030101FF 30170603
  551D1104 10300E82 0C536368 756C6D61 6E5F4150 32301F06 03551D23 04183016
  80146572 E97D10CD 163AF273 E3767819 299AF074 C7D6301D 0603551D 0E041604
  146572E9 7D10CD16 3AF273E3 76781929 9AF074C7 D6300D06 092A8648 86F70D01
  01040500 03818100 725801C1 C20AFDFE B7B00412 F768DD3F C6A32AD7 F3EC33EA
  4042C90D EF286704 E2E9EABF EB4C8A13 18FC345F DE416CEB F2EB81C8 615FEA37
  D8BE5742 85475AE7 D4EFB5EC A747E70A F6ABF07B 3E0C30AB FB1D3329 3BF022BB
  689A5C74 14AFF773 290EA752 BB82E701 3198371C B57C19E6 70643D6E 24BEE7FF
  C57A89D0 9135240D
  quit
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 15 mode ciphers tkip
ssid xtreme
ssid xtreme50
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.15
encapsulation dot1Q 15
no ip route-cache
bridge-group 15
bridge-group 15 subscriber-loop-control
bridge-group 15 block-unknown-source
no bridge-group 15 source-learning
no bridge-group 15 unicast-flooding
bridge-group 15 spanning-disabled
interface Dot11Radio0.20
encapsulation dot1Q 20
no ip route-cache
bridge-group 20
bridge-group 20 subscriber-loop-control
bridge-group 20 block-unknown-source
no bridge-group 20 source-learning
no bridge-group 20 unicast-flooding
bridge-group 20 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid xtreme
ssid xtreme-guest
antenna gain 0
no dfs band block
channel width 40-above
channel dfs
station-role root
bridge-group 1
interface Dot11Radio1.15
no ip route-cache
bridge-group 15
interface Dot11Radio1.20
no ip route-cache
bridge-group 20
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.15
no ip route-cache
bridge-group 15
interface GigabitEthernet0.17
description *** Management Vlan ***
encapsulation dot1Q 17 native
no ip route-cache
bridge-group 1
interface GigabitEthernet0.20
no ip route-cache
bridge-group 20
interface BVI1
ip address 172.100.17.50 255.255.255.0
no ip route-cache
ip default-gateway 172.100.17.254
no ip http server
ip http authentication local
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
logging 172.17.15.16
snmp-server community 87e5f6a953 RW
bridge 1 route ip
line con 0
login local
line vty 0 4
login local
end
hello blakerone,
Your using wpa2/aes correct?
Scott Fella
Sent from my iPhone
-Scott
I am using WPA-PSK and TKIP
Scott, it is WPA2-PSK and i am using TKIP which i think is the dafault for WPA2?
thanks for the help
No... wpa uses tkip and wpa2 uses aes
Scott Fella
Sent from my iPhone
-Scott
On the 5GHz radio set your channel to be something other than DFS, like channel 36.
Steve
HTH,
Steve
fb_webuser
Level 6
Level 6
radio preamble long
fb_webuser
Level 6
Level 6
change:preamble to long , disable aironet extension, DTIM to 10 or 75
Radio pream
Please forgive me if the etiquitte is to start a new post but I am having the EXACT issue the thread-starter was so I was hoping to get help on this thread since several experts with this issue seem to already be in place here.
Info:
* WAP running latest firmware
* I have two SSIDs (Internal and Guest)
* Both SSIDs use WPA2 and AES-CCM.
My radio config, after reading the tips above, looks like this:
no ip address
no ip route-cache
encryption vlan 2 mode ciphers aes-ccm
encryption vlan 3 mode ciphers aes-ccm
ssid Guest
ssid Internal
antenna gain 0
mbssid
no preamble-short
station-role root
beacon dtim-period 75
no dot11 extension aironet
My desktops/laptops can connect to both SSIDs all day with no problem, but when I try to connect any iDevice, it asks for the password, seems to take it fine, and then just "spins" forever, never to get an IP.  If I look at associations from an SSH session, I see:
SSID [Guest] :
MAC Address    IP address      Device        Name            Parent         Stat
c09f.xxxx.xxxx 0.0.0.0         unknown       -               self           Assoc
(The C09f.xxxx.xxxx is my iPhone that will never get an IP).
Please help if you have any ideas, or direct me to create a new thread and I'll certainly do that.
Brian
Try lowering your dtim to 2
Scott Fella
Sent from my iPhone
-Scott
