iPhones/iPads WMM support
CB90021204
Hi, does anyone know if iPhones or iPads support Wifi Multimedia (WMM)?
George Stefanick
Indeed
http://support.apple.com/kb/ts3727
George Stefanick
Indeed
We've seen where i-Devices do not stream media correctly when we enable WMM as allowed or required.  Once set to disabled (at the WLAN) all media functions normally.  Impacted applications range from YouTube, iTunes, etc.  Might be something in our environment (7.4.100.0 - 1142/3502 APs) or configuration but we've not found a workaround yet.  Hopefully your experience is better.  We'd really like to leverage WMM.
Anthony
Have you configured Adimission Controll for Video (Under 802.11 a/n or 802.11b/g/n -> Media -> Admission Controll-ACM ). If so this is a bug (CSCud67358). If you are hitting this bug workaround is either Disable 802.11n or disable Video ACM.
I think by disableing WMM, effectively you are disabling 802.11n, so I suspect you are experiencing this issue.
Let us know
Rasika
