Is point-to-multipoint(5GHz)+wifi(2.4GHz) with 4 air AP1242AG possible and how?
I have a little experience with cisco routers but none with the air AP1242AG.
The project i am working now is about giving wifi to a village. There is one ADSL router, one switch (2690) and several AP1242AG.
Is it possible to have the following topology?
Can i use one of the AP as a master and connect through a sector antenna the other access points using the 5GHz interface, and also use the 2.4GHz interface for hosts to connect?
Can you help with the configuration for both the "master AP" and the "client APs"? if you have a similar configuration it would vey much appreciated.
Thank you very much for your time.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Is point-to-multipoint(5GHz)+wifi(2.4GHz) with 4 air AP1242A
Yes it is possible to bridge on the 5ghz and have client access on the 2.4ghz. Now having a working config to show you is a bit difficult. Here are a few links that should help. The main thing is that you setup the 5ghz as a bridge and the role would be root bridge and all the other would be non root bridge. The client access would be root access point
https://supportforums.cisco.com/docs/DOC-16087
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008058f53e.shtml
-Scott
-Scott
Hi Scott
Thank you very much for this, i am working on these examples now.
I was trying to find something like this but i couldn 't in the "chaotic" Cisco tutorials and guides.
And another question.
Do i have to use a different Vlan for each non toute bridge 1242 in order to have point to multipoint?
Thanks again
Alex
Well just remember that all autonomous ap's require that the ap management ip address is the native vlan, if you plan on separating the managment vlan from wireless user traffic.  If you don't care, you can have the wireless users and the ap on the same vlan and you just have to configure an ip address with no subinterfaces on the AP.
Here is a link on how to setup multiple vlans:
https://supportforums.cisco.com/docs/DOC-14496
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Hi Scott,
I din't quite unerstand what you mean. I only have the native Vlan 1
My problem is that when i set the AP's to Non root bridge mode, the interface dot11radio 1 goes down and is in reset state. If i set it to root bridge it goes up. Am i missing something else in my configuration? i tried to follow the examples you posted.
Do you think if i posted the configurations might help?
Thank you.
Alex
Hi Scott,
I finally realized why the dot11Radio 1 interface wouldn't go up, it needed to authenticate with the root AP 's interface.
I had tried open auth, open auth with mac and LEAP, but it didn't work (maybe my config was wrong).
So i set wpa2 authentication between the 5GHz interfaces and everything worked.
I left everything (management and hosts) on the native vlan as you set, maybe I'll put the hosts on a different vlan later, for security reasons.
I am posting my configuration so if you see something wrong, unnecessary or missing please let me know.
root bridge
version 12.4
no service pad
service password-encryption
hostname BaseAP
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
dot11 ssid bridging
   vlan 1
   authentication open
   authentication key-management wpa version 2
   guest-mode
   infrastructure-ssid
   wpa-psk ascii key
dot11 ssid fotolivosHotspot
   authentication open
   guest-mode
power inline negotiation prestandard source
username user1 privilege 15 password pass1
username user2 privilege 15 password pass2
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
antenna transmit right
antenna receive right
antenna gain 6
channel 2412
station-role root access-point
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
encryption vlan 1 mode ciphers aes-ccm tkip
encryption mode ciphers aes-ccm tkip
ssid bridging
antenna gain 8
dfs band 1 3 block
channel dfs
station-role root bridge
interface Dot11Radio1.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.1.253 255.255.255.0
no ip route-cache
ip default-gateway 192.168.1.254
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
bridge 1 route ip
line con 0
line vty 0 4
end
And the configuration of one of the non root bridge AP's
version 12.4
no service pad
hostname StationAP1
enable secret pass
aaa new-model
dot11 ssid bridging
   vlan 1
   authentication open
   infrastructure-ssid
   wpa-psk ascii "key"
   authentication open
   guest-mode
bridge irb
no ip address
no ip route-cache
antenna gain 8
channel 2437
bridge-group 1
no ip address
no ip route-cache
ssid bridging
antenna gain 8
station-role non-root
no ip route-cache
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.1.252 255.255.255.0
no ip route-cache
ip http server
bridge 1 route ip
line con 0
line vty 0 4
end
Thanks again for the help
BR
Alex
1016
