Is there a specific WS-SUP720-BASE IOS version for a WiSM being upgraded to 7.0.220 from 6.0.202?
Any advice or link a support matrix for this would be amazing - thanks.
VIP Purple
HI;
I dont know, if thsi is the answer of your question or not
You can directly upgrade to 7.0.220.0
Upgrade path:
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_0_220_0.html
Here is the comaptibility matrix :
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
Reagrds
Dont forget to rate helpful posts
Thanks for the reply.
I think Ive phrased my question wrong - what i meant to say was is there a minimum sup level required in order to run 7.0.220 on the WiSM?
VIP Purple
Ok now i got your point.
As per my knowledge , you can directly upgarde the WISM software to 7.0.220.0.
You dont need to worry about sup720, there is no need for specific version on this.
Hall of Fame Super Gold
The firmware of the IOS does not decide your 6500 Supervisor.
IF you want to use WiSM-1, regardless of the firmware you have inside, then your supervisor card should be a Sup720 running IOS version SXF2.
This is all you need.
169
