Is there anyway to allow MAC authentication when Web Auth is used?
I would like to have certain MAC addresses not have the need to login to the Web Auth page in our guest access setup.
Is this feature possible?
SD
Re: Is there anyway to allow MAC authentication when Web Auth is
I have the same request. any solutions ?
Thanks.
Even though you can configure both MAC filtering and WEB auth on the same WLAN, it will always need to do web auth, i.e., they will always need to login to the Web Auth page in your guest access setup.
HTH,
Tiago
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
358
