ISE 1.2 Sponsor Group - "View/Edit Accounts" Setting not working as expected
we need a sponsor account that is not allowed to see the Account List (so the Accounts that were created) on the sponsor UI. The sponsor should be only allowed to create an account, to send his credentials via E-Mail or to print them.. and that's all
So I configured the rights as you can see in the attachment, but when I choose No for "View/Edit Accounts" the user is able to see ALL ACCOUNTS. When I just choose "Own Accounts" then the user sees just his own Accounts, so the 2nd setting works properly.. the first behaviour seems like a bug to me.. did anyone else have had this problem too?
Thanks!
Everyone's tags (1)
1 ACCEPTED SOLUTION
Choose one of the following
Choose one of the following options for View/Edit Accounts:
No—Sponsors are not allowed to edit any guest accounts.
All Accounts—Sponsors are allowed to edit/view all guest accounts.
Group Accounts—Sponsors are allowed to edit guest accounts created by anyone in the same sponsor user group.
Own Account—Sponsors are allowed to edit only the guest accounts they created.
Silver
Also check the given link for
Also check the given link for sponsor portal (configuration) and covers all the given field in details required for deployment
http://www.cisco.com/c/en/us/td/docs/security/ise/1-2/user_guide/ise_user_guide/ise_guest_pol.html
114
