ISE Guest Wifi Portal Users restricted to 5 day account
I have a custom Guest wifi portal configured in Mulit-Portal Configuration to do self service, Portal Type is default Portal.
I have the Guest Portal Policy configured to a time profile of 6 months which works ok for my other wifi profiles.
My users however are only getting a 5 day account to expiry.
I suspect the Guest Portal I have configured is not using the Default Guest Portal Policy as configured in "Web Portal Management\Settings\Guest\Portal Policy but I can't find any other option or settings
Please Any help gratefully recieved.
What is the ISE version and
What is the ISE version and patch level ?
There was a bug that caused a
There was a bug that caused a failure like this, think it was solved in 1.2 patch 8...  could be worth a try to patch if you haven't done so....
103
