issue accessing the GUI with a cisco 1200 series
D0nprintup_2
I was able to access the gui by typing in the address 192.168.1.10 and was prompted for a login screen.
On the login screen the realm was level_1_access.
username/password.
I attempted to do a IOS upgrade and it would not let me, stated no access to the flash.
I rebooted the AP and now when I goto 192.168.1.10 i get a login prompt but the realm is now level_15_access.
Once I log in I do not get the GUI anymore. I only get the following:
Cisco Systems
Accessing Cisco AIR-AP1230B-A-K9 "AP-131"
Show diagnostic log - display the diagnostic log.
Monitor the router - HTML access to the command line interface at level 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15
Show tech-support - display information commonly needed by tech support.
Extended Ping - Send extended ping commands.
Can someone tell me what happened and how do I get the Gui back?
Aaron
Looks like your GUI got deleted off of flash.
It should be in flash:/YOURVERSION/html .
Instead, you're seeing the generic IOS HTML GUI.
I'd recommend doing a full IOS reinstall now.
Get to the ap# prompt (telnet/ssh/console) then:
ap#archive download-sw /force /overwrite tftp://ios-tarfile
Good luck,
Aaron
ios-tarfile <--- I can download the new TAR file and do a IOS upgrade at the same time?
Yes, the AP autonomous IOS software is distributed as a tar file, which consists
of the IOS image proper, the GUI, the radio firmware images, and other stuff.
You DON'T upgrade APs as you would a router (with "copy tftp flash"); you need
to use the archive command, which untars the tarball and puts everything from it
into its proper place.
http://www.cisco.com/en/US/docs/wireless/access_point/12.3_8_JA/configuration/guide/s38mfw.html#wp1035644
thank you
