Issue connection wireless clients and AP reboot
Hi all,
I have 2 problems in my Wifi infrastructure.
1) All my AP's reboot randomly, the 1st reboot was after a power failure of all the building. the 2nd one was yesterday, but we don't know why...
Here are the logs : ap_logs.png
2) I have motorola 9190 connected to a specific SSID, our customer use these motorola to scan the merchandising. They disconnect some times and they have to reconnect manually again, or reboot the scanner...
Here you can find the logs also: scan_logs.png
Here you can see the client was connected at 8h03, and disconnected at 8h05...
If someone can help me, because i really don't understand what is going on...
Thanks in advance,
Alexis
VIP Purple
What version of software
What version of software you run on your WLC ? Also what AP model is this ? Need some info
Rasika
Hello, I have 2 WLC's in HA
I have 2 WLC's in HA mode. WLC version on both is 7.6.120.0 and AP's are 2602 :)
Alexis
VIP Purple
Stay away from this code... I
Stay away from this code... I would recommend you to go for 7.6.130.0 (7.6 MR3) when it releases within next couple of weeks.
Then see whether problem persist
Rasika
**** Pls rate all useful responses ****
Hall of Fame Super Gold
I agree with Rasika.  Stay
Stay away from 7.6.120.X.  If you can't wait for the next release, contact TAC and they'll give you an engineering fix.
Lots of problems with 7.6.120
Lots of problems with 7.6.120.0 version ? Should I have to go back to and old version ?
Which one is the best ?
Thanks in advance,
Alexis
81
