ISSUE WITH BRIDGE AIR-BR1410A
I have two Air-Bridges 1.8 miles which when the two bridges was lined up and these are the best values ​​obtained after several tests
Values ​​are:
BR-1410A (root)     BR-1410A (non-root)
-58 dbi                            -60dbi
54 M                               54 M
Power 24
Ver IOS 12.4 (24D)JA2
The channel is the best in the middle with less than 30% of saturation
Tests were made with the wireless link using a tool Solar wins (wan-killer) to pass a traffic AIR-bridge to the other and had a favorable desempño as 22 megs, but when put in the wireless enlance produccione this began to problems generate 12 megawatts, causing slow users, IP calls cut.
Network traffic from one point to another not exceed the 10 Megas
Do you have some ideas?
Best regards
VIP Purple
Re: ISSUE WITH BRIDGE AIR-BR1410A
If you are doing VoIP across this bridge link, make sure QoS is correctly configured to get required priority for voice traffic. Below post may help you to determine what it involve.
http://mrncciew.com/2013/08/02/a-wireless-bridge-with-qos/
Post "show dot11 associations " output of the Root AP to see how is the connection established during problamatic time.
Rasika
**** Pls rate all useful responses ****
Already have QoS configured on the two wireless links, these are my results to sh Dot11 associations
Rout Bridge
sh dot11 associations 003a.9a36.6e8f
Address           : 003a.9a36.6e8f     Name             : WLTOLSACHAPAL
IP Address        : 10.10.10.23        Interface        : Dot11Radio 0
Device            : bridge             Software Version : 12.4
CCX Version       : 5                  Client MFP       : Off
State             : Assoc              Parent           : self
SSID              : WLCHAPALTOLSA
VLAN              : 0
Hops to Infra     : 1                  Association Id   : 1
Clients Associated: 1                  Repeaters associated: 0
Tunnel Address    : 0.0.0.0
Key Mgmt type     : WPA PSK            Encryption       : TKIP
Current Rate      : 54.0               Capability       : WMM ShortHdr
Supported Rates   : 12.0 18.0 24.0 36.0 48.0 54.0
Voice Rates       : disabled           Bandwidth        : 20 MHz
Signal Strength   : -58  dBm           Connected for    : 83751 seconds
Signal to Noise   : 33  dB            Activity Timeout : 30 seconds
Power-save        : Off                Last Activity    : 0 seconds ago
Apsd DE AC(s)     : NONE
Non rout
LTOLSACHAPAL#sh dot11 associations 001a.a1f3.7f23
Address           : 001a.a1f3.7f23     Name             : WLCHAPALTOLSA
IP Address        : 10.10.10.13        Interface        : Dot11Radio 0
Device            : br1410             Software Version : 12.4
State             : Assoc              Parent           : -
VLAN              : 0
Hops to Infra     : 0                  Association Id   : 1
Current Rate      : 48.0               Capability       : WMM ShortHdr
Signal Strength   : -60  dBm           Connected for    : 83626 seconds
Signal to Noise   : 31  dB            Activity Timeout : 15 seconds
These values ​​are not to be in production for the new values ​​that require a window would need to put into production the Bridges.
VIP Purple
As per these values your bridge is established 48Mbps at the moment you get these statistics.
You mentioned you got 22 Mbps througput when testing which also reasonbaly accurate (remember due to half duplex nature you won't get uplink/downlink 54Mbps, but half)
What is the round trip deley between two VoIP endpoints when call is made across this bridge ?
Rasika
I don´t have this value that you request.
But The problem is not only with calls, affects the entire network for both voice and data. Because the  trouput low as 10Mbps or even less
And this happens only when we put it into production the wireless link
232
