Issue with Cisco 1410 Bridge Connections
I have a Point to Mulitpoint connection. On top of a tower i have an cisco 1410 bridge with an omni antenna. I have 3 other sites that are currently connected to the omni from about 1,2, and 6km away. I am adding 2 more sites that are 8 and 9 km away. These are the ones that aren't working. We are using cisco 1410 bridges with a 28db dish. I used the outdoor bridge calculator and it should work but at 48MBps. But I can't get it working. The omni bridge does see them and they see the omni brdige but it is up and down and they don't associate fully. If you look on the association tab they are listed under Others and the State is Assocation processiong. Also the messages in the event log are :
Mar 1 06:27:35.384 UTC Warning Packet to client 0024.97a3.8141 reached max retries, removing the client
2 Mar 1 06:27:35.345 UTC Information Interface Dot11Radio0, Station Site80 0024.97a3.8141 Reassociated KEY_MGMT[NONE]
3 Mar 1 06:27:35.199 UTC Information Interface Dot11Radio0, Deauthenticating Station 0024.97a3.812b Reason: Previous authentication no longer valid
4 Mar 1 06:27:35.198 UTC Warning Packet to client 0024.97a3.812b reached max retries, removing the client
5 Mar 1 06:27:35.168 UTC Information Interface Dot11Radio0, Deauthenticating Station 0024.97a3.8141 Reason: Previous authentication no longer valid
6 Mar 1 06:27:35.168 UTC Warning Packet to client 0024.97a3.8141 reached max retries, removing the client
7 Mar 1 06:27:35.132 UTC Information Interface Dot11Radio0, Station Site37 0024.97a3.812b Reassociated KEY_MGMT[NONE]
8 Mar 1 06:27:35.100 UTC Information Interface Dot11Radio0, Station Site80 0024.97a3.8141 Reassociated KEY_MGMT[NONE]
9 Mar 1 06:27:34.940 UTC Information Interface Dot11Radio0, Deauthenticating Station 0024.97a3.8141 Reason: Previous authentication no longer valid
10 Mar 1 06:27:34.940 UTC Warning Packet to client 0024.97a3.8141 reached max retries, removing the client
11 Mar 1 06:27:34.894 UTC Information Interface Dot11Radio0, Station Site80 0024.97a3.8141 Reassociated KEY_MGMT[NONE]
12 Mar 1 06:27:34.775 UTC Information Interface Dot11Radio0, Deauthenticating Station 0024.97a3.812b Reason: Previous authentication no longer valid
13 Mar 1 06:27:34.775 UTC Warning Packet to client 0024.97a3.812b reached max retries, removing the client
14 Mar 1 06:27:34.729 UTC Information Interface Dot11Radio0, Station Site37 0024.97a3.812b Reassociated KEY_MGMT[NONE]
over and over again for each of the bridges. What does this mean? I think it might be an alignment issue but wonder if there could be other issues.
Thanks for any info.
1 REPLY
Re: Issue with Cisco 1410 Bridge Connections
Are all data rates enabled? Clear line of sight with plenty of free space? What does 'sh dot11 assoc all' show for signal strength/SNR when associated?
193
