Issue with Ciso AIR-LAP1142N-A-K9 AP configuration
I have trouble accessing the internet from my laptop after installing Ciso AIR-LAP1142N-A-K9 AP.
The  AP are connetected to my router (which has a DHCP enabled) via a switch  and each has a Fix IP address with network mask, gateway and DNS  already configured. When I triy to connect to the access point, only the  IP address and network mask are automatically assigned to the my  laptop. and I have to manually input the gatway and DNS to be able to  navigate the internet.
I would like to know which configuration  will allow any node that tries to connect the internet via the access  point to be automatically configured to access the internet after  authentification.
I will appreciate any help in solving the issues.
Best Regards,
Re: Issue with Ciso AIR-LAP1142N-A-K9 AP configuration
Do we hv the default configured on the ap??
Please find attached the configuration  we currently have on the AP
Last files
Thanks again for your assistane.
are you using vlan's ? if so trunk the ports that the AP's are connect to.
879
СоздатьДля создания публикации, пожалуйста в систему
