Issues with Aironet 1231AG performance ~ 1 Mbit on LAN!!
Hey guys!!
Before I start let me say that I'm just starting to get into the world of cisco wireless networking and I'm still very new to all this so please bear with me!! I'm doing my best to research everything before I ask any questions
The problem I am having is that I've added a 2nd AP in my home network however, I'm only getting ~1mbps throughput even from my LAN! And it's not a coverage issue since I'm getting a solid signal and 54mbps connection.
So let me take it from the start..
I've added a new Cisco 1231AG AP to 2nd floor because I had no coverage there (40$ on ebay btw.. which is crazy!!). Before that I only had wifi coverage on the ground floor of my house with the integrated AP of my 877W router.
My setup is the following and unfortunately due to the cabling being mounted, it cannot be changed:
here's a simple diagram:
now unfortunately my 2 switches are cheap oem made so I cannot trunk the port from the 877.
So with my laptop I get a throughput of ~2MB/sec on the ground floor when connected to the 877
and I get ~100KB/sec when connected on the 1231AP on the 1st floor!!
I have no interference from anywhere and when I unplug the ethernet cable from the AP and plug it to my laptop I get good 100mbps performance.
Can you please have a look at my configs below and help me out or at least point me to the right direction on how I go about troubleshooting this issue? Where do I look? Where should I start from?
I am desparate because I've tried everything and spent countless hours researching the whole setup from scratch and with no prior knowledge.
877w config
version 12.4
no service pad
boot-start-marker
boot system flash c870-advipservicesk9-mz.124-24.T.bin
boot-end-marker
logging message-counter syslog
no logging buffered
enable secret 5 $1$Vwq5$trYsQTJsOu/jbwBpGY/AN1
aaa new-model
aaa authentication login default local
aaa authorization exec default local
dot11 syslog
dot11 ssid TheMatrix
vlan 1
authentication open
authentication key-management wpa
mbssid guest-mode
wpa-psk ascii 0 XXXXXX
ip source-route
no ip dhcp use vrf connected
ip dhcp binding cleanup interval 200
ip dhcp excluded-address 10.0.0.1 10.0.0.20
ip cef
ip inspect name dyndns tcp router-traffic timeout 3600
no ipv6 cef
ntp server 195.167.30.249
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
no cdp enable
interface FastEthernet1
no cdp enable
interface FastEthernet2
no cdp enable
interface FastEthernet3
no cdp enable
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers aes-ccm
ssid TheMatrix
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2412
station-role root
no cdp enable
interface Dot11Radio0.10
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description Internal Network (The Matrix LAN)
no ip address
ip nat inside
ip virtual-reassembly
bridge-group 1
interface Dialer0
description External Network
ip address negotiated
ip nat outside
ip virtual-reassembly max-reassemblies 64
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer string "*99#"
dialer-group 1
no cdp enable
ppp ipcp dns request
interface BVI1
description Bridge to Internal Network (The Matrix Lan)
ip address 10.0.0.10 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
ip http authentication local
ip http secure-server
ip dns server
snmp-server community ipBalanceTest RO
control-plane
bridge 1 route ip
line con 0
password xxxx
logging synchronous
no modem enable
line aux 0
line vty 0 4
exec-timeout 45 0
password xxxxx
logging synchronous
transport input ssh
end
AP - 1231AG config
! No configuration change since last restart
version 12.4
no service pad
service password-encryption
logging rate-limit console 9
aaa new-model
aaa session-id common
no ip domain lookup
ip domain name thematrix.lan
dot11 syslog
   vlan 1
   authentication open
   authentication key-management wpa version 2
   mbssid guest-mode
   wpa-psk ascii 7 xxxxxxxx
bridge irb
no ip address
no ip route-cache
ssid TheMatrix
mbssid
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2437
station-role root
no dot11 extension aironet
no cdp enable
no ip route-cache
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface BVI1
ip address 10.0.0.8 255.255.255.0
no ip route-cache
ip default-gateway 10.0.0.10
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 protocol ieee
bridge 1 route ip
line con 0
password 7 xxxx
line vty 0 4
exec-timeout 60 0
logging synchronous
sntp server 134.214.100.6
end
Bronze
Can you provide a "show controllers dot11radio 0" on the AP as well as "show dot11 associations "?
Re: Issues with Aironet 1231AG performance ~ 1 Mbit on LAN!!
Sure...
here it is:
#show dot11 associations 0012.176c.63f4
Address           : 0012.176c.63f4     Name             : NONE
IP Address        : 10.0.0.26          Interface        : Dot11Radio 0
Device            : unknown            Software Version : NONE
CCX Version       : NONE               Client MFP       : Off
State             : Assoc              Parent           : self
SSID              : TheMatrix
VLAN              : 1
Hops to Infra     : 1                  Association Id   : 2
Clients Associated: 0                  Repeaters associated: 0
Tunnel Address    : 0.0.0.0
Key Mgmt type     : WPAv2 PSK          Encryption       : AES-CCMP
Current Rate      : 48.0               Capability       : WMM ShortHdr
Supported Rates   : 1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Voice Rates       : disabled           Bandwidth        : 20 MHz
Signal Strength   : -64  dBm           Connected for    : 40322 seconds
Signal to Noise   : 32  dB            Activity Timeout : 60 seconds
Power-save        : Off                Last Activity    : 0 seconds ago
Apsd DE AC(s)     : NONE
Packets Input     : 2721528            Packets Output   : 559932
Bytes Input       : 311681726          Bytes Output     : 473651535
Duplicates Rcvd   : 1544               Data Retries     : 205679
Decrypt Failed    : 0                  RTS Retries      : 18983
MIC Failed        : 0                  MIC Missing      : 0
Packets Redirected: 0                  Redirect Filtered: 0
Session timeout   : 0 seconds
Reauthenticate in : never
the second one is very long, so I'm sorry about that
show controllers dot11Radio 0
Radio AIR-AP1131G, Base Address 0024.c4ae.3990, BBlock version 0.00, Software version 6.30.25
Serial number:
Number of supported simultaneous BSSID on Dot11Radio0: 16
Carrier Set: Americas (US) (-A)
Uniform Spreading Required: No
Configured Frequency: 2437 MHz  Channel 6
Allowed Frequencies: 2412(1) 2417(2) 2422(3) 2427(4) 2432(5) 2437(6) 2442(7) 2447(8) 2452(9) 2457(10) 2462(11)
Listen Frequencies: 2412(1) 2417(2) 2422(3) 2427(4) 2432(5) 2437(6) 2442(7) 2447(8) 2452(9) 2457(10) 2462(11) 2467(12) 2472(13) 2484(14)
Beacon Flags: 0, Interface Flags 20105, Interface Events 0, Mode 9; Beacons are enabled; Probes are enabled
High Density mode disabled
  Local Rx sensitivity (Config -80, Max -60, Min -11) dBm
        CCA Sensitivity -60 dBm
  Cell  Rx sensitivity -80 dBm, CCA Sensitivity -60 dBm
Configured CCK Power: 20 dBm
Configured OFDM Power: 20 dBm
Active power levels by rate
     1.0 to 11.0  , 20  dBm
     6.0 to 54.0  , 17  dBm, changed due to regulatory maximum
  OffChnl Power: 20, Rate 1.0
Allowed CCK Power Levels:  -1 2 5 8 11 14 17 20
Allowed OFDM Power Levels: -1 2 5 8 11 14 17 20
Allowed Client Power Levels: 2 5 8 11 14 17 20
Receive Antennas : right-a left-b
Transmit Antennas : right-a left-b
Antenna: internal, Gain: Allowed 8, Reported 8, In Use 8
Active Rates:  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Current Rates:  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Allowed Rates:  1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
All Rates:  1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Default Rates:  basic-1.0 basic-2.0 basic-5.5 basic-11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Best Range Rates:  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Best Throughput Rates:  basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
Current Voice Rates:  basic-5.5 basic-11.0 6.0 12.0 24.0 [disabled until voice packet-discard enabled]
Default Voice Rates:  basic-5.5 basic-11.0 6.0 12.0 24.0
Managment Rates:  basic-1.0
Multicast Rates:  basic-1.0
Data Rate Sensitivity (rate, SNR dB, Contention dBm)
( 1.0, 10, -93)   ( 2.0, 10, -92)   ( 5.5, 11, -90)   (11.0, 14, -90)
( 6.0, 15, -89)   ( 9.0, 16, -88)   (12.0, 18, -88)   (18.0, 19, -86)
(24.0, 20, -85)   (36.0, 24, -81)   (48.0, 27, -78)   (54.0, 31, -77)
ERP settings:.
Neighbors in non-erp mode:
Number of MFP Indices: 10
RFID Tag Detection: Disabled
Multicast Address filtered:
Packet type filtered:
00 0C rm_scn
Probe limit: active off, filter on, count 0, time 0
Assoc limit: active off, count 0, time 0
Radio Management (RM) Configuration: Regular AP, Mode 1, Disabled
MCST RSCs: [0]0x0 [1]0x0 [2]0x0 [3]0x0 [4]0x0 [5]0x0 [6]0x0 [7]0x0 [8]0x0
TKIP Cum Stats: STA            MIC-L-Errs MIC-R-Errs Replay   C-Measure
                0000.0000.0000 00000000   00000000   00000000 00000000
AES-CCMP Cum Stats: 00000000 replays discarded
QBSS Load: 0x9, Policing Stats: Rx downgrades 0, Tx downgrades 0
Classifier Stats tx_on_up6  0, tx_on_up4 0
Configured Local Access Class Parameters
  Back      : cw-min 4 cw-max 10 fixed-slot 7 admission-control Off txop 0
  Best      : cw-min 4 cw-max 6 fixed-slot 3 admission-control Off txop 0
  Video     : cw-min 3 cw-max 4 fixed-slot 1 admission-control Off txop 3008
  Voice     : cw-min 2 cw-max 3 fixed-slot 1 admission-control Off txop 1504
Configured Cell Access Class Parameters
  Best      : cw-min 4 cw-max 10 fixed-slot 3 admission-control Off txop 0
  Video     : cw-min 3 cw-max 4 fixed-slot 2 admission-control Off txop 3008
  Voice     : cw-min 2 cw-max 3 fixed-slot 2 admission-control Off txop 1504
SIP stats sip_udp_rx_pkt 0, sip_tcp_rx_pkt 0,
                            downlink classified_pkt 0,
                            uplink classified_pkt 0,
                            num_processed_SIP_Calls 0
Transmit queues: Limit 650 Current 0 In-Progress 0
       ---- Active --- In-Progress --------------- Counts --------------
       Cnt Quo Bas Max Cnt Quo Bas       Sent   Discard  Fail    Retry  Multi
Uplink   0   0   0   0   0   0   0          0         0     0        0      0
Voice    0   0   0   0   0   0   0       4759         0    15      332    132
Video    0   0   0   0   0   0   0          0         0     0        0      0
Best     0   2 645   2   0   2 103   15612538       927    11  1543520 908775
Mcast    0   1   5   0   0   1   2     241929       693     0        0      0
Back     0   0   0   0   0   0   0     241929       693     0        0      0
BSSIDS Index Flags State Next Held Defer NonDefer Clients Tsf Dtim Txq
  3990     0    00     3    0    0     0        0       1   0    2   0e
Driver TX blocks: in use 0, high 0, at reset 0, fail 0 drop 0
Off Channel Metrics: Timeouts - Tx 0 Beacon 0 DTIM MC Waits 0
---Clients     AID VLAN      Status    Age  Tx   Mode Enc Key       Rate
0012.176c.63f4   2    1 00 140 000 0FF 59   0-0  0190 200 0-10 1EFF0000 048 048
e806.8899.d4f4   3    1 00 160 000 0FF 22   0-0  01B0 200 0-10 1EFF0000 06C 06C
74f0.6d70.8791   1    1 00 140 000 0FF 59   0-0  0190 200 0-10 1EFF0000 048 06C
                 RxPkts KBytes  Dup Dec Mic   TxPkts  KBytes  Retry RSSI SNR
0012.176c.63f4  2721964 304435 1563   0   0   560173  462630 224772   63  33
e806.8899.d4f4   224076  20248   59   0   0   323394  428560 122153   56  39
74f0.6d70.8791   386264  91128  243   0   0   261541  112378 165466   66  31
               IP Address      Pauses   RSC
0012.176c.63f4 10.0.0.26       00008  [0]0x2B9C60 [5]0x2AA05E
e806.8899.d4f4 10.0.0.36       00000  [0]0x121B [1]0x100A [6]0x1213
74f0.6d70.8791 10.0.0.13       00007  [0]0x1286E
Video Report:  Cnt  Rate  Retries/Tot
8021x auth in prog -74 allowed 0
Vlan BSSID   Clients PSP Pri HT Encr  Key0 Key1 Key2 Key3 SSIDs MFP
   0  3990 0       0   0   0  0    0
   1n 3990 0       1   1   0  0  214       x128           TheMatrix 0
0 0 flags 3 match 7
Protocol 55
Registers: io E8000000 mem 80000000 aux A0000000
0000 FF50 0000 0000 0021 0000 0000 0000
0001 0000 0000 0000 0000 0000 0000 0000
0000 0000 0000 0000 0000 0000 0000 0000
0100 0407 0000 0000 0020 0B88 E39D 0504
0000 0000 0000 0000 61B4 007C 0000 CFCC
00000000 C8091000 00A02202 FFDFFF7D FFDFF7FF 00000000 02008101 00010024
FFFFFBE2 00002FFF A10424E4 08224280 00000000 00000000 0000800C 00008041
00000000 00000000 00000000 00000000 0000E262 000021DE 00000000 0000982A
Radio running:  temp 0 C tx_power 20 bb_code 0x0
    rssi_threshold 0x0 gain offset 0 platform 1
PCI sys_id: 0xA506 subsys_id 0x7100 (0x7101)
Unicast ciphers 0x0 mcast ciphers 0x0
Rid Ring:
A0000970: 00B88000 21D6A1BC * n
Rx Ring:
A0000950: 89380000 21B1125C * v, 89380000 21C4D2B4   v
A0000960: 89380000 21B3CC84   v, 89380000 21B19BE0   v
Tx Ring:
A0000800: 00368000 21BF1460   n, 00368000 21B3CC8C   n
A0000810: 00368000 21A8A474   n, 00368000 21C6EE38   n
A0000820: 00368000 21BFC834   n, 00368000 21B3CC8C   n
A0000830: 00368000 219061BC * n, 00368000 21B65C64   n
A0000840: 00368000 21B2A45C   n, 00368000 21C4D2BC   n
A0000850: 00368000 21B19BE8   n, 00368000 21D69754   n
A0000860: 00368000 21B11264   n, 00368000 21CBE398   n
A0000870: 00368000 21C4D2BC   n, 00368000 21D69754   n
A0000880: 00368000 21904824   n, 00368000 21CDD4C4   n
A0000890: 00368000 21B30E24   n, 00368000 21D21650   n
TxDn Ring:
A0000930: 802C0000 21D6A9C4   v, 802C0000 21D6AAA4   v
A0000940: 802C0000 21D6AB84 * v, 802C0000 21D6AC64   v
Multicast counters:
Internal MC counts:
241929 (45321) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0) 0 (0)
-Channel Range-  -------Rates------ Max Power   Allowed
  1 to  11 by 1  1.0    to 11.0     20        -1 2 5 8 11 14 17 20
                 6.0    to 54.0     17
        DOT11 Statistics (Cumulative Total/Last 5 Seconds):
RECEIVER                               TRANSMITTER
Host Rx K Bytes:    2491069 / 49       Host Tx K Bytes:       1542610 / 2
Unicasts Rx:       20045919 / 10       Unicasts Tx:          15725116 / 6
Unicasts to host:  20045919 / 10       Unicasts by host:     15391202 / 4
Broadcasts Rx:     48891290 / 622      Broadcasts Tx:         5550614 / 49
Beacons Rx:        23960233 / 307      Beacons Tx:            5395157 / 49
Broadcasts to host:24445645 / 311      Broadcasts by host:     155457 / 0
Multicasts Rx:            0 / 0        Multicasts Tx:          312565 / 4
Multicasts to host:       0 / 0        Multicasts by host:     312565 / 4
Mgmt Packets Rx:     490963 / 4        Mgmt Packets Tx:        322866 / 2
RTS received:       5321882 / 4        RTS transmitted:        221655 / 0
Duplicate frames:    337048 / 0        CTS not received:        67028 / 0
CRC errors:        13049474 / 117      Unicast Fragments Tx: 15713853 / 6
WEP errors:              64 / 0        Retries:               2921810 / 0
Buffer full:              0 / 0        Packets one retry:      634945 / 0
Host buffer full:         0 / 0        Packets > 1 retry:      908907 / 0
Header CRC errors:       13 / 0        Protocol defers:        903463 / 5
Invalid header:      287688 / 0        Energy detect defers:   141199 / 0
Length invalid:           0 / 0        Jammer detected:            14 / 0
Incomplete fragments:     0 / 0        Packets aged:                0 / 0
Rx Concats:               0 / 0        Tx Concats:                  0 / 0
RATE 1.0
Rx Packets:        25448350 / 317      Tx Packets:                582 / 0
Rx Bytes:          3723053705 / 50286    Tx Bytes:                87386 / 0
RTS Retries:            421 / 0        Data Retries:              716 / 0
RATE 2.0
Rx Packets:          261654 / 0        Tx Packets:               1782 / 0
Rx Bytes:          23803269 / 0        Tx Bytes:               347677 / 0
RTS Retries:           3483 / 0        Data Retries:             8345 / 0
RATE 5.5
Rx Packets:          202358 / 0        Tx Packets:               7337 / 0
Rx Bytes:          19218276 / 0        Tx Bytes:              2336049 / 0
RTS Retries:           3699 / 0        Data Retries:            23387 / 0
RATE 11.0
Rx Packets:          289601 / 0        Tx Packets:             276694 / 0
Rx Bytes:          28224583 / 0        Tx Bytes:            204900428 / 0
RTS Retries:          22589 / 0        Data Retries:           197896 / 0
RATE 6.0
Rx Packets:             108 / 0        Tx Packets:               4883 / 0
Rx Bytes:             17650 / 0        Tx Bytes:              1521445 / 0
RTS Retries:           1295 / 0        Data Retries:            10031 / 0
RATE 9.0
Rx Packets:             162 / 0        Tx Packets:              10412 / 0
Rx Bytes:             34471 / 0        Tx Bytes:              4513260 / 0
RTS Retries:           1611 / 0        Data Retries:            12847 / 0
RATE 12.0
Rx Packets:          219056 / 0        Tx Packets:             158369 / 0
Rx Bytes:          20054911 / 0        Tx Bytes:             51930753 / 0
RTS Retries:          12898 / 0        Data Retries:           176343 / 0
RATE 18.0
Rx Packets:          316679 / 0        Tx Packets:             734894 / 0
Rx Bytes:          34821189 / 0        Tx Bytes:            297599301 / 0
RTS Retries:          19127 / 0        Data Retries:           386589 / 0
RATE 24.0
Rx Packets:          415832 / 0        Tx Packets:             913672 / 0
Rx Bytes:          48328810 / 0        Tx Bytes:            489669894 / 0
RTS Retries:            556 / 0        Data Retries:           442062 / 0
RATE 36.0
Rx Packets:         1376589 / 1        Tx Packets:            2624601 / 2
Rx Bytes:          209773038 / 340      Tx Bytes:           2107799563 / 734
RTS Retries:            438 / 0        Data Retries:           735446 / 0
RATE 48.0
Rx Packets:         2789931 / 1        Tx Packets:            3148052 / 1
Rx Bytes:          450645559 / 40       Tx Bytes:           2515068504 / 54
RTS Retries:              0 / 0        Data Retries:           615165 / 0
RATE 54.0
Rx Packets:        13171244 / 2        Tx Packets:            7509823 / 1
Rx Bytes:          2287534272 / 85       Tx Bytes:             88655082 / 60
RTS Retries:              0 / 0        Data Retries:           246866 / 0
Multicast throttle drops: 0
Client TX pause count: 455
Media Direct Band Configuration
        Unicast Video Redirect = 0
        Client Min Phy Rate = 0
        Max Retry Percentage = 0
Dot11 Current Video Transmission Metrics:
        Arrivals:0 Q-Drops:0 Tries:0 Agg:0 Success:0 Fail:0
Dot11 5-second Video Transmission Metrics:
        Arrivals:0 Tries:0 Agg:0 Success:0 Fail:0
        Radio-Q-Peak:0 Video-Q-Peak:0 Video-Q-Drops:0
        Delay - Tot Msec:0 10/20/40/40+ Msec:0/0/0/0
Dot11 1-second Video Transmission Metrics:
        Q-util:0 max-tx-time:0 p-chan:34 p-video:0 L/r:0
Last radio reset code: 37
Radio resets - total:14 retries:0 failed:0
Reset Stats: -- Start Cnt: 3,   Recovery:  Cnt 0Last Ret: 0, Fails: 0, Recovery Status: Stalled? NO, In Prog? NO
   Code/Count: 37/00010 67/00001 68/00003
Log Buffer:
I tried again to transfer a local file through the wifi when connected to the AP and I got around 150KB/sec...
any thoughts?
Hall of Fame Super Gold
You sure you don't have speed/duplex mismatch?
well show int fa # shows 100mb/s full on both ap and router and they're both on auto so I guess I'm not having a mismatch. (I have no way of checking the oem switches).
Although I have to admit that I was hopping that it would be that.
Let me ask you something else that I haven't fully understood.
Since I'm not trunking the port to the AP (because if I did I, the computer on the 1st oem switch would word right?), the traffic that goes out is not tagged with a VLAN id 1 right ? It's sent untagged and the AP is able to communicate with the 877 because they're both having VLAN 1 as their native vlan. Is that right ?
Is there any chance it has something to do with Vlan tagging or not really ?
Any ideas? Any thoughts anyone?
I know that it's not the easiest thing to go through someone else's configs but even bullet points and a slight direction would be appreciated more than you know.
Bronze
No, VLAN tagging wouldn't have anything to do with this.
Everything looks good from a physical layer standpoint on the wireless.  Do a "sh fa0.1" and make sure there are no errors on the AP.    You might also look at the switchport side just to be sure.
Try taking off WPA-PSK so that you're just running unencrypted.
Then I'd try turning off some of the lower data rates on the wireless.
     "no speed  basic-1.0 2.0 5.5"
     "speed basic-11.0"
If none of that helps I'd start to suspect faulty hardware.
I will do and will report back!
Thank you for the help!!
1074
