Community Member
issues with app download on anchored WLAN
We are having this strange issue where the mobile devices conected over the anchored SSID have problems when downloading apps. initially it was only related to the google play store. we upgarded from 7.2 to 7.4 and now the issues extended to apple store app download as well. the applications install only to a certain percent (we think is always the same percent fro the same application, but not 100 % sure), and then stall. any help or hint will be much appreciatted,
thank you,
Alejandro
VIP Purple
Are these guest SSIDs
Are these guest SSIDs (WebAuth) or normal dot1X SSIDs ? Do you have any ACLs applied for these ?
Rasika
Community Member
Hi Rasika, SSID are guest
Hi Rasika,
SSID are guest (webauth), we have a pre-auth acl applied on the anchor for the guest SSID (it might no be even necesary i think).
Thank you
VIP Purple
If you do any other file
If you do any other file downloads will that work ? Have you tested with multiple client devices to ensure it is happening across all the end point OS (eg iOS 6.x, 7.x or android x.x)
Also see whether any timing on when application download stalls (ie after 3min, 5 min, ect)
Also are you running 7.4.121.0 in 7.4 path.
Rasika
**** Pls rate all useful responses ****
Community Member
Hi Rasika,i tried a few large
Hi Rasika,
i tried a few large downloads without problems, tested from a few android versions and 7.0 and 6.0 in IOS. i've noticed the percent during the install is almost the same for a given app, but will have to test again to see if there is a "pattern" in the time interval as well. runing on 7.4.121, both the foreing and the anchor controller.
thanks again for taking your time to think about this issue.
52
