issues with cisco 1242 aironets
We are currently experiencing and issue with the 1242 AG Wireless Access Points. We have have them configured as 1 Root Access point and 3 Repeaters. The repeaters seem to be experiencing frequency interference issues. The Root AP is using antenna model 2506 and the repeaters 1728's.
What happens is when the repeaters are first started up, they see / communicate to the root access point fine, but within 5 minutes they stop communicating. If we manually set the channel to something different, they see each other for 5 - 10 minutes then eventually disappear and cannot be ping'd or seen with a sh cdp nei.
We have tried various combinations of settings so far. Have tried channel 1 - 13 and the least conjested frequency mode. It usually settles on channel 8 when we put it in that mode. But it is the same sceneario each time. All 3 repeaters show up almost instantly after a channel change, but slowly disappear in less than 10 minutes.
Here is our config:
Version
Cisco IOS Software, C1240 Software (C1240-K9W7-M), Version 12.4(21a)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 16-Sep-09 19:06 by prod_rel_team
ROM: Bootstrap program is C1240 boot loader
BOOTLDR: C1240 Boot Loader (C1240-BOOT-M) Version 12.3(7)JA1, RELEASE SOFTWARE (fc1)
ROOTAP uptime is 2 days, 3 hours, 14 minutes
System image file is "flash:/c1240-k9w7-mx.124-21a.JA1/c1240-k9w7-mx.124-21a.JA1"
cisco AIR-AP1242AG-E-K9    (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FCZ112782K9
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:1C:58:B1:72:2E
Part Number                          : 73-10256-06
PCA Assembly Number                  : 800-26918-05
PCA Revision Number                  : A0
PCB Serial Number                    : FOC11262N5Z
Top Assembly Part Number             : 800-29233-01
Top Assembly Serial Number           : FCZ112782K9
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1242AG-E-K9
Configuration register is 0xF
Root AP Config
Current configuration : 1987 bytes
version 12.4
no service pad
service password-encryption
hostname ROOTAP
no aaa new-model
dot11 syslog
dot11 activity-timeout client maximum 120
dot11 activity-timeout repeater maximum 300
dot11 ssid WIRELESS
   authentication open
   authentication key-management wpa
   guest-mode
   infrastructure-ssid
username user privilege 15 secret 5 password
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid WIRELESS
antenna gain 5
parent timeout 10000
channel 2417
station-role root access-point
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
no dfs band block
channel dfs
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.2.10 255.255.255.0
no ip route-cache
ip default-gateway 192.168.2.1
ip http server
ip http authentication local
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
privilege level 15
logging synchronous
login local
stopbits 1
line vty 0 4
privilege level 15
logging synchronous
login local
stopbits 1
line vty 5 15
privilege level 15
logging synchronous
login local
stopbits 1
end
Repeater Config
Current configuration : 1764 bytes
version 12.4
no service pad
hostname REPEATER03
no aaa new-model
dot11 syslog
dot11 ssid WIRELESS
   authentication open
   guest-mode
   infrastructure-ssid
bridge irb
no ip address
no ip route-cache
ssid WIRELESS
antenna gain 5
station-role repeater
bridge-group 1
no ip address
no ip route-cache
shutdown
no dfs band block
channel dfs
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.2.13 255.255.255.0
no ip route-cache
ip http server
bridge 1 route ip
line con 0
privilege level 15
logging synchronous
login local
stopbits 1
line vty 0 4
privilege level 15
logging synchronous
login local
stopbits 1
end
We are wondering if you have any tips to get around this.
Also,  should these access points be able to handle ~200 clients? How close to the root access point should the repeaters be placed? I basically just go until my signal gets low and put a repeater within that range. Could vary from 30-60 meters away.
Hall of Fame Super Gold
Re: issues with cisco 1242 aironets
APs, in theory, can handle >1,200 clients.  In theory.  In practice, Cisco recommends between 12-25 clients.  Imagine if you have, say, 50 clients and they are trying to access the network on a 100 Mbps FastEthernet connection.  That slows them down, right?  But consider wireless as a broadcast.  One talks and the rest listens.
Thanks for the info, explains why ours is getting contrary with any more than 100 or so.
2104
