L2 WLAN Roaming between APs connected to WS-CE500 switches
I´ve connected several AP1200s connected to a WS-CE500 switch with Smartport Role Wireless configured on the switch.
Additionally I´ve configured several VLANs on the APs and the Switch.
Everything works fine except Layer2 Roaming between the APs. On the Switch I can see a security violation at the appropriate Port.
Is there a way to get this running?
Thanx in advance,
Geri
Re: L2 WLAN Roaming between APs connected to WS-CE500 switches
make sure that the coverage areas are overlapping just a bit. This should help because the first AP tells the others and the switch that the station is deauthenticating to roam to another AP
Pay attention to WDS. WDS should be configured do speed up the roaming. I think it will increase the roaming performance.
Nuno
125
