Community Member
LAP 1552CU-E-K9 not working with power injector AIR-PWRINJ1500-2=
Dear All,
Appreciate your kind support with this issue,
I have 12 device of LAP 1552CU not working with 12 power injector AIR-PWRINJ1500-2=
when ever I plug the cable from the power injector to the AP it's not working
Please advice
Thanks in Advanced,
Ahmed
Everyone's tags (5)
1 ACCEPTED SOLUTION
Re: LAP 1552CU-E-K9 not working with power injector AIR-PWRINJ15
Hey Ahmed,
My understanding is the power injector is not supported for the 1552CU and your only powering options are the following:
1552C/1552CU
• 40-90 VAC, 50-60 Hz, quasi-square wave, Power over Cable
• 12 VDC
http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps11451/data_sheet_c78-641373.html
Cheers,
Erwin
Cheers, Erwin ______________________________________ How helpful was I? Don't forget to rate me when you have the chance!
Hey Ahmed,
1552C/1552CU
• 12 VDC
Cheers,
Erwin
Community Member
Many thanks Man,
you are totally right,
Ahmed,
642
