Community Member
Large Bed and Breakfast Wireless Network
I need some advice on setting up what is probably a very unique wireless network. My client wants me to set up a wireless network for their guests in a bed and breakfast which happens to be a castle. It is very pricey to stay there so the wireless will be free, but they do want a splash page. Also it is a very large property and has many thick walls. There are also suites in the turrets of the outer wall so the wireless will need to cover a large area. It is all hard wired (including the four suites in the turrets and some mechanical rooms near/on the roof) but I am not completely sure what direction I should go in as far as wireless set up goes. Any advice would be wonderful!
Re: Large Bed and Breakfast Wireless Network
YOu can use Cisco WLAN controller for configuring the splash page.
Here is the config example-
Also check here for more info.
