leap aes roaming
hello,
What kind of roaming can I expect with the following setup :
- leap authentication
- aes encryption
- windows CE scanner and funk odyssey supplicant. ccx v3.
- WLC 4402
- AP1242
I think that roaming is possible with tkip, but here I'm not doing tkip but aes.
Green
Re: leap aes roaming
I'm pretty sure it'll do OK, depending on how "seamless" your application needs the connection to be.
I use LEAP and EAP-FAST (WPA2)with my iPAQ (Mobile 5) and the Odessey supplicant and have no issues roaming ... but my application is not sensitive to connectivity gaps.
Testing is the only way to be certain.
Good Luck
Scott
thanks.
138
