10-09-2008 11:28 AM - edited 07-03-2021 04:35 PM
I have old handheld devices that are using LEAP authentication to a local radius server. They are currently connected to IOS based access points. I am trying to convert the site to controllers /lwapp, but I cannot
get LEAP to work through the controller. (All other clients/devices are working fine).
Here are the settings for my ssid/radio that the clients use for LEAP on the IOS based ap's:
ssid xxxxxx
authentication open eap eap_methods
authentication network-eap eap_methods
int ...radio0
encryption mode ciphers tkip wep128
broadcast-key change 900
I've tried every option under the controller - wlans -> security -> layer 2, but the handhelds still don't get an IP address or connect correctly. Any ideas? Or is LEAP just not compatable with WCS?
10-13-2008 12:27 AM
Have you configured the WLC(s) as NAS on the radius server?
What kind of RADIUS server are you using?
Anything in the logs on it when it fails?
10-13-2008 03:15 AM
I'm currently having some problems with LEAP and Intel 2200BG wifi cards. Maybe your problem only comes from your wireless NIC.
