04-17-2007 07:48 PM - edited 07-03-2021 01:57 PM
I connect a LAP1131 to power injector and its led status change to amber? what means this? The AP is registered in the wireless lan controllers but its Operational status is Down. I selected the "power injector states" check box.
04-19-2007 02:27 PM
not sure if this will help, but assuming the ap's are plugged into a cisco switch you have to turn CDP off on the ports you are using.
i had a similar problem with a group of 1242's i had on older cisco switches. turned cdp off and it worked fine.
04-19-2007 02:28 PM
