Community Member
Lenovo Laptops can't find 802.11a network
I have a AIR-AP1131AG-K-K9 installed in Korea and it's configured in LWAPP/HREAP mode. All laptops can connect to the 802.11bg radio. Some laptops can connect to the 802.11a radio but no Lenovo T61 or X61 laptops can connect to the 802.11a network. The Lenovo machines don't even see the 802.11a signal in the air. Any tips?
1 REPLY
Bronze
Re: Lenovo Laptops can't find 802.11a network
You should verify whether your lenovo laptops are compatible with the cisco APs. There is a page called CCX compatibility matrix which should help you to know this. You can find this page in cisco.com
150
