05-11-2002 05:32 AM - edited 07-04-2021 11:09 PM
Anyone from the Wireless BU out there????
The lightening arrestor with grounding ring will not fit when the bridge is mounted against the wall.
Makes for a sloppy install. This has proved to be a real problem.
Is this going to be changed anytime soon ????
-pat
05-11-2002 09:41 PM
We have Bridges all ove the campus mounter right againts the wall( no spacers in between) and the Lightning arrestors were placed with out any trouble..
What make are you using ?
Would you like to know the brand we are using ?
05-12-2002 04:05 AM
Thanks for the response. We are using the arrestor part # AIR-ACC3354
I don't have the make in front of me. Not sure if these are any different from the ones a few Months ago or not.
But there is no way that these will fit with the ground lug attached with the bridge (350 metal case) flat against the wall.
I will up date this post tomorrow with the specific brand and we can compare.
thanks again
-pat
05-13-2002 06:31 AM
Update on brand of Lightening arrestor. The brand is Huber+Suhner
#3406.99.0001
Are there more than One? We simply use the Cisco part number
AIR420-003354
-pat
05-13-2002 01:07 PM
Its Huber+Suhner.
I got a chance to see my crew install it, they are suing the 8 gauge copper wire with the lug on it.
After you mentioned it I did aks them if it was tough. I will try and get a picture of it. I am curious since we have few more installs.
After that we would not have any problems since the AP1200 models have a mounting plate supplied.
