limited or no connectivity
Hi all,
This is my first time to configure AP, I configure the access point using the basic setting, no security. After configuration, my pc with wireless can find the SSID, but not able to connect to network. Message is "limited or no connectivity", What is the possible problem?
Thanks in advance!
Below is the configuration:
Aironet1250#sh run
Building configuration...
Current configuration : 1874 bytes
version 12.4
no service pad
service password-encryption
hostname Aironet1250
enable secret 5 $1$VBk3$2h/AT4preTZ3TCGBIyIHE0
no aaa new-model
dot11 ssid Test
authentication open
guest-mode
power inline negotiation prestandard source
username Cisco password 7 13261E010803
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
ssid Test
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid Test
dfs band 3 block
speed basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel width 40-above
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.1.240.2 255.255.255.0
no ip route-cache
ip default-gateway 10.1.240.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Silver
Re: limited or no connectivity
Your configuration looks valid. Limited or no connectivity means it didn't get an IP address, so maybe the problem is with your LAN?
Try unplugging your AP from the network and plugging a PC in. See if you get an IP address that way. If not, post your switch config and maybe we can troubleshoot there.
Thanks, When I pluged a PC in, still not able get a IP address from dhcp.
Actually, when I tried to connect wireless PC through AP, the PC got a public ip address (169.x.x.x), but did not get a default gateway.
Below is the configuration in the 3750 switch:
hostname Hi
username cisco privilege 15 secret 5 $1$RCae$FYrcGuBvlkc9TbDwHoQme/
no aaa new-model
clock timezone EST -5
clock summer-time EDT recurring
switch 1 provision ws-c3750g-48ts
system mtu routing 1500
ip subnet-zero
ip routing
ip domain-name economicalinsurance.com
ip name-server x.x.x.x
ip name-server 10.1.115.215
ip dhcp excluded-address 10.100.96.1
ip dhcp excluded-address 10.100.96.100
ip dhcp excluded-address 10.100.96.61
ip dhcp pool VOICE
network 10.100.96.0 255.255.255.0
option 150 ip 10.100.96.50
default-router 10.100.96.1
ip multicast-routing distributed
crypto pki trustpoint xxx
crypto pki certificate chain xxx
certificate self-signed 01
quit
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
vlan internal allocation policy ascending
class-map match-all Class-Data-Hi
match access-group name ratabase-app
interface GigabitEthernet1/0/1
switchport trunk allowed vlan 1-1005
switchport mode trunk
interface GigabitEthernet1/0/2
Silver
169.x.x.x isn't a public address, it's actually called an "Automatically Provisioned IP Address", or APIPA. It means that you aren't getting a DHCP address, so now we're getting somewhere.
To help troubleshoot, I'll need to see your VLAN 1 interface configuration. Can you paste that in? Is the DHCP pool "VOICE" on the switch the pool that you want to hand out the address?
359
