limiting client associations per lightweight AP
Can anyone tell me if it is possible to limit the number of clients that can associate per lightweight AP?
Re: limiting client associations per lightweight AP
yes, it is possible.
Advanced Primary SSID Setup Link in your access point takes you to the AP Radio Primary SSID page, from which you can configure the primary SSID settings. From this page, you configure IEEE 802.11x authentication, EAP, unicast address filters, and the maximum number of associations for the radio?s primary SSID.
OR, if you have multiple VLANs, you can go to
VLAN Security Policy section. You can define a security policy for each VLAN on the access point. This enables you to define the
appropriate restrictions for each VLAN you configure and you can configure Maximum number of associations?ability to limit maximum number of wireless clients per SSID
hope to help ... rate if it does ....
At this point in time, there is no way on the controller to limit the number of associations like you can do in the IOS world. However, you can influence it with the client threshold setting in the auto-rf configuration.
Mark
189
