Community Member
Line Extension with Power Injector: yes or no?
the lenght of the lan segment between switch and access point is cca 150m.
my quiestion is:
can i solve this problem with inserting Power injector (AIR-PWRINJ3) between, so resulting shema would be:
AP--70m(PoE)--PowerInj--80m(normal LAN)--sw2950
is it Injector in the function of L2 switch or is it only injecting power into normal 100m limited segment?
thx for answer
1 REPLY
Re: Line Extension with Power Injector: yes or no?
I tried this before, did not work. I think it's passive.
You have to use a fiber(MM does the trick and it's cheap, you dont need really clean terminaison for 100baseFX, mecanical with do)
or put a hub somewere.
121
