Linux drivers for cisco a/b/g wireless PCI card (AIR-PI21AG-A-K9)
Where I can get the Linux dirvers and how to install in linux system for Cisco wireless PCI card part no (AIR-PI21AG-A-K9)
Kind Regards
Ranga Kishore
9885030063
1 REPLY
Green
Re: Linux drivers for cisco a/b/g wireless PCI card (AIR-PI21AG-
Many / most of the Linux distributions include drivers for the Atheros chipset .... these drivers should work OK with the Cisco a/b/g card.
Which distribution are you using, and, have you loaded the Wireless packages (also sometimes included with the "laptop" software packages.
Good Luck
Scott
703
