Little Wave Lan
I want to connect 2 PCs 800 m one from the other in the city with a speed of at least 128Kb, the best antena i can get here is 900 MHz (no 2.4 GHz).
Do you have something?
1 REPLY
Bronze
Re: Little Wave Lan
If you are restricted to 900 MHz I don’t know of any product giving you that range. With 2.4 GHz, the Aironet 350 products will give you a 600 meter range with about 1Mbps throughput with the right antenna’s and no obstructions. If you can put a bridge as a repeater half-way there or so, you’ll get your 800 meters.
154
