Looking for 5760 QoS configuration example to solve 7925 phone connection problems
we still have problems to connect 7925 phones with a 5760 controller. First we had suspected, the channel allocation because the controller had 8 of 12 APs with the same channel config. Now we use only a-standard with manual channel config but the phone says: "connection failed" and "leaving service area".
The last hope is a good QoS config for 5760 controller. Can anyone recommend a good qos config.
May be the qos config so important that a phone can not connect without it? Our wireless network is not in use by nobody so far.
Thanks in advance.
1 ACCEPTED SOLUTION
VIP Purple
Hi,Please check this, Very
Please check this, Very nice written by Rasika.
http://mrncciew.com/2013/12/22/3850-qos-part-1/
May be it helps.
VIP Purple
May be it helps.
Hello,the reason was the QoS
the reason was the QoS config. Now everything works well with this config:
class-map match-any Voice-egress_Voice_UI_CLASS
description Voice_UI_CLASS DO_NOT_CHANGE
  match  dscp ef
class-map match-any non-client-nrt-class
  match non-client-nrt
policy-map Voice-egress_Child_Policy
description UI_POLICY_DO_NOT_CHANGE UI_Child_Policy
class Voice-egress_Voice_UI_CLASS
    priority level 1
    police 128000000
    admit cac wmm-tspec
      rate 128000
      wlan-up  6
description [SSID_Egress_UI_policy UI_POLICY_DO_NOT_CHANGE]
class class-default
   set dscp dscp table Voice-egress_UI_table
   set wlan user-priority dscp table Voice-egress_UI_table
    shape average 128000000
    queue-buffers ratio 0
   service-policy Voice-egress_Child_Policy
policy-map Voice-ingress
description [SSID_Ingress_UI_policy UI_POLICY_DO_NOT_CHANGE]
class class-default
   set dscp dscp table Voice-ingress_UI_table
policy-map voice
class class-default
   set cos 6
wlan SSID_voice 3 SSID_voice
aaa-override
accounting-list default
client vlan Voice_VLAN
no exclusionlist
security wpa akm cckm
security dot1x authentication-list default
service-policy input Voice-ingress
service-policy output Voice-egress
session-timeout 1800
no shutdown
Gold
Please refer the document :
63
