Looking for standalone AP
kpoon
I am looking for a standalone AP that can have seperate guest SSID. We have about 20-30 devices connected on a given day. I've looked at 1140, 1260 but not sure what exactly the differences are besides one has internal antenna. There are also other models such as 1042, 1142, 1262, etc. kinda confusing.
What is your suggestion?
Thanks.
The AP's with external antennas are more rugged and the internal antenna ap's are more for the office type environment.  Not much of a difference in performance, each AP, does have their unique RF patteren.
-Scott
7 Replies 7
Scott Fella
If you don't want the external antennas, the only main difference between the 1142 and the 1040 is that the 1142 is a 2x3x:2 and the 1040 is a 2x2:2.
So two receive two transmit and two spatial streams for the 1040 and two transmit and three receive and two spatial streams for the 1142.
The 1040 is the low end version of the 1142.
-Scott
I would go with the 1142:)
-Scott
Thanks, so the 1260 is the same as 1140 but with external antennas? There's no performance or feature advantages?
-Scott
thank you very much!
No problem. Thanks for using the rating system.
-Scott
