Losing IP connection to BR350
I recently installed two BR350 Bridges to connect a remote site.
It seems that if I stay in the remote bridges web page very long looking at settings I lost the connection and can no longer ping the bridge. The root bridge still shows the association but the only way to regain access via IP is to power cycle the bridge. The bridges have static IP addresses. Specifically I updated the firmware to possibly address the situation... after loading on the root (local) bridge it rebooted itself and I regained connection. After loading the firmware on the remote I lost my connection and an hour later still could not ping the bridge until I manually power cycled it.
Any ideas?
1 REPLY
Bronze
Re: Losing IP connection to BR350
If possible, try swapping the bridges to see if the bridge that was in repeater mode locks you out when it is in root mode. If it still locks you out then you may need to replace it with another bridge. You should as well check the antenna and antenna connections for the repeater.
108
