12-07-2017 07:54 AM - edited 07-05-2021 07:56 AM
This all happened before my time. One of the offices was remodeled and the APs were placed above the ceiling. They were reconnected to the switch when the remodel was done. I don't have access to wiring diagrams to see where the other ends are located. I see the APs on the switches but they are associated with a controller that is no longer around. I found that out through Prime.
Is there a way to reset these APs to where I can get them onto another controller? We use option 43 in DHCP to tell them which controller to associate with.
12-07-2017 08:16 AM
Hi @glhowe
Do see those AP on Prime? If does, so just change WLC config.
If you don't, then you can change the DHCP option to reflect the desired WLC and then reset all AP. If they used PoE from this switch would easy, if they use local power source, can be a little tricky.
-If I helped you somehow, please, rate it as useful.-
12-07-2017 08:51 AM
12-07-2017 09:18 AM
This message means that they are not on Prime actually. What you are seeing is an entry on the Prime database from when the AP was on the network but the AP is not on Prime anymore.
Try to telnet to the AP from the switch and issue the command 'capwap ap controller ip address <IP-address>'
Otherwise, you need to console the AP and see what happen.
12-07-2017 09:33 AM
12-07-2017 11:50 AM
Well, if the APs are still connected to the switch then you can find out what their IP addresses are (using CDP) and remote into them.
Once there, just re-home the APs to their new controllers using the command "capwap ap primary <WLC name> <WLC IP address>".
12-07-2017 12:14 PM
12-07-2017 01:43 PM
Connection refused because Telnet/SSH to the APs are disabled, by default.
