LWAP join problem
two LWAPs seem to try to join the WLC, unsuccessfully. I see messages from 'debug capwap errors enable' for both of the LWAPs like this:
*Oct 20 12:45:06.361: 00:27:0d:55:b3:f0 Join Priority Processing status = 0, Incoming Ap's Priority 2, MaxLrads = 250, joined Aps =212
*Oct 20 12:45:17.813: 00:27:0d:55:b3:f0 PHY_TX_POWER_PAYLOAD: Invalid Tx Power Level 0
*Oct 20 12:45:20.824: 00:27:0d:55:b3:f0 DTLS connection was closed
'debug capwap events enable' says, again, for both of the APs:
*Oct 20 13:22:12.325: 00:3a:98:87:5a:e0 Join Request from 10.67.52.13:3288
*Oct 20 13:22:12.326: 00:3a:98:87:5a:e0 Join Version: = 100714244
*Oct 20 13:22:12.326: 00:3a:98:87:5a:e0 Join resp: CAPWAP Maximum Msg element len = 88
*Oct 20 13:22:12.326: 00:3a:98:87:5a:e0 Join Response sent to 10.67.52.13:3288
*Oct 20 13:22:12.326: 00:3a:98:87:5a:e0 CAPWAP State: Join
*Oct 20 13:22:12.326: 00:3a:98:87:5a:e0 capwap_ac_platform.c:1207 - Operation State 0 ===> 4
*Oct 20 13:22:12.326: 00:3a:98:87:5a:e0 Register LWAPP event for AP 00:3a:98:87:5a:e0 slot 0
*Oct 20 13:22:12.327: WARP IEs: (12)
*Oct 20 13:22:12.327:      [0000] dd 0a 00 c0 b9 01 00 00 00 08 01 01
*Oct 20 13:22:12.329: 00:3a:98:87:5a:e0 Register LWAPP event for AP 00:3a:98:87:5a:e0 slot 1
*Oct 20 13:22:12.525: 00:3a:98:87:5a:e0 Configuration Status from 10.67.52.13:3288
*Oct 20 13:22:12.525: 00:3a:98:87:5a:e0 CAPWAP State: Configure
*Oct 20 13:22:12.525: 00:3a:98:87:5a:e0 spamVerifyRegDomainSlot: (slot 1) unsupported radio type 0XFF.
*Oct 20 13:22:12.526: 00:3a:98:87:5a:e0 spamVerifyRegDomainSlot: (slot 1) unsupported radio type 0XFF.
*Oct 20 13:22:12.526: Invalid channel 0 spacified for the AP REPLACED, slotId = 1
*Oct 20 13:22:12.526: 00:3a:98:87:5a:e0 Updating IP info for AP 00:3a:98:87:5a:e0 -- static 1, 10.67.52.13/255.255.255.0, gtw 10.67.52.1
*Oct 20 13:22:12.526: 00:3a:98:87:5a:e0 Updated IP Domain info for AP 00:3a:98:87:5a:e0 -- set 0, Domain
*Oct 20 13:22:12.526: 00:3a:98:87:5a:e0 Updating IP NamServer info for AP 00:3a:98:87:5a:e0 -- set 0, nameserver 0.0.0.0
The version of the controller is 6.0.199.4.
Have you got any idea?
Peter
  • Other Wireless - Mobility Subjects
Re: LWAP join problem
I have seen this when the regulatory domain check in not passing, that's why WLC is not sending the config response.
I would double check the model of the AP and the country code configured on the WLC to make sure they are compatible.
Can you share with us the complet part number of the AP and the sh run-config from the WLC?
Tiago
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
the info on the AP I can get in this moment is:
Cisco, AIR-LAP1131G-E-K9 - 802.11g AP, Single MPCI Radio, Int Ant, ETSI
I won't be able to post the whole running config of the WLC but you may have enough information with the following:
(replaced) >show run-config no-ap
System Inventory
NAME: "Chassis"    , DESCR: "Cisco Wireless Controller"
PID: AIR-CT5508-K9,  VID: V01,  SN: replaced
Burned-in MAC Address............................ 00:24:97:CE:EB:C0
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 250
Press Enter to continue or to abort
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 6.0.199.4
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS
System Name...................................... replaced
System Location.................................. replaced
System Contact................................... replaced
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
IP Address....................................... 10.100.2.11
Last Reset....................................... Software reset
System Up Time................................... 44 days 3 hrs 45 mins 24 secs
System Timezone Location.........................
Current Boot License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
Next Boot License Type........................... Permanent
Configured Country............................... DE  - Germany
--More or (q)uit current module or to abort
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +42 C
External Temperature............................. +29 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 4
3rd Party Access Point Support................... Disabled
Number of Active Clients......................... 240
Switch Configuration
802.3x Flow Control Mode......................... Disable
FIPS prerequisite features....................... Disabled
secret obfuscation............................... Enabled
Network Information
RF-Network Name............................. WLAN-WAN
Web Mode.................................... Disable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Enable
Secure Shell (ssh).......................... Enable
Telnet...................................... Enable
Ethernet Multicast Forwarding............... Disable
Ethernet Broadcast Forwarding............... Disable
AP Multicast/Broadcast Mode................. Unicast
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
Cisco AP Default Master..................... Disable
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Disable
Mgmt Via Dynamic Interface.................. Disable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Mesh Full Sector DFS........................ Enable
AP Fallback ................................ Enable
Web Auth Redirect Ports .................... 80
Fast SSID Change ........................... Enabled
IP/MAC Addr Binding Check .................. Enabled
Port Summary
           STP   Admin   Physical   Physical   Link   Link
Pr  Type   Stat   Mode     Mode      Status   Status  Trap     POE    SFPType
1  Normal  Forw Enable  Auto       1000 Full  Up     Enable  N/A     1000BaseSX
2  Normal  Forw Enable  Auto       1000 Full  Up     Enable  N/A     1000BaseSX
3  Normal  Disa Enable  Auto       Auto       Down   Disable N/A     Not Present
4  Normal  Disa Enable  Auto       Auto       Down   Disable N/A     Not Present
5  Normal  Disa Enable  Auto       Auto       Down   Disable N/A     Not Present
6  Normal  Disa Enable  Auto       Auto       Down   Disable N/A     Not Present
7  Normal  Disa Enable  Auto       Auto       Down   Disable N/A     Not Present
8  Normal  Disa Enable  Auto       Auto       Down   Disable N/A     Not Present
Ok, so the reg domain is good and the country code also...
Leads only to on root cause...Radio is indeed dead...and the solution is to replace the AP...so i would open a TAC case and ask for an RMA.
HTH,
Tiago
774
