lwapp to autonomous
CISCO LWAPP TO AUTONOUMOUS MODE CONFIGURATION:
(HERE WE USED CISCO AIRONET 1131 AG)
1->DELETE THE OLD FLASH FILE FROM THE CISCO WIFI
Connect Ethernet cable and console cable.
  #delete
  -It will ask to delete what , then delete the old flash file
 -NOTE: Now we can only able to get into the router’s recovery mode because we erased old flash
  -EX for recovery mode----à ap:
2->DOWNLOAD THE TFTP32 APPLICATION SOWTWARE(run tftp server on 10.0.0.2/24)
 - Set ip for the pc which we using as 10.0.0.2/24
  -Subnet: 255.255.255.0
  -Default gateway:10.0.0.10
  -Run the tftp to download the IOS image from the working cisco router, follow step (3)
3->DOWNLOAD CORRECT IOS IMAGE FROM THE OTHER USING CISCO ROUTER(SAME 1130 INCASE)    else  in CISCO.COM
       To download ios to tftp:
       NOTE:ALWAYS CONNECT ETHERNET CABLE WITH PC TO WIFI TO TRANSFER IOS
        Log into the working cisco router and follow the below mentioned command to copy ios to tftp
      #archive upload-sw /version c1130-k9w7-mx.124-21a.JY  tftp://10.0.0.2/ c1130-k9w7-mx.124-21a.JA1.tar
        Note: don’t ever forget to give version above command
      -now it will upload the CORRECT  image ios file into TFTP path.
      - when you checked the path in the tftp server it shows the file name as .tar.tar twice at the last
       So simply erase one .tar( Make it with only .tar)
4->ENTER  CISCO WIFI ROUTER  THROUGH CLI
       Note: ensure we can only able to work  in the recovery mode (EX: ap)
      ap: tftp_init
      ap: ether_init
      ap: flash_init
      ap: tar -xtract tftp://10.0.0.2/images/c1130-k9w7-mx.124-21a.JA1.tar flash:
     note:don’t ever forget to give /images , else it will prompt the error like (no such  file   directory found)
     now it will extract the image ios into the router
     ap:set
    BOOT=flash:/c1130-k9w7-mx.124-21a.JA1
     Note : don’t give extension as .tar
     NOW
   ap: reset
    (in ap: mode we use reset for reload , instead of reload in wifi router)
   5->SIMPLY CONFIGURE IP AND GATEWAY TO USE THE ROUTER
80
