ā09-19-2013 02:50 PM - edited ā07-04-2021 12:53 AM
Using a scannign tool I am seeing the following when I connect to my Cisco 1142 Access point.
E02F6DC4BDEF 198EB2/4 6686A7198E2/4
Can anybody tell me what these #ers are? I do not see my AP mac address in here and was wondering what the 2nd set of #ers are.
ā09-24-2013 06:01 AM
Please check the below links which can be helpful for you:
Link-1
http://www.cisco.com/en/US/docs/wireless/access_point/12.2_15_JA/configuration/guide/s15filt.html
Link-2
ā09-24-2013 07:38 AM
what you are seeing is probably the BSSID for the SSID you connected to.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
ā09-26-2013 04:05 PM
Normally when you are using scanning tools you see two things that is the SSID and concerning mac alonge with the channel information but if you use packet capturing tools we can also see the probes and its depends on which tool are you using if you can provide the screen shot of the tool alonge with the capture data we can provide better reply
