MAC Address Filtering - Aironet1130AG
ZiPPygEEk
I'm attempting to block about 10 to 15 users on the wireless by using  MAC address filtering on the Aironet.  I referenced the following link:
http://egementanirer.blogspot.com/2009/ ... dress.html
The  policy does indeed work, but once I apply the filter all traffic on the  wireless for that particular VLAN stops.  Why would this happen?  I  wouldn't think I need to configure anything else for this to work, but  maybe I'm wrong.
I was looking over the config and I noticed that each time I added a MAC address to the filter, it would create and access-list 701 deny 0000.0000.0000  ffff.ffff.ffff   Once I removed this access-list, traffic starting flowing again, but  when I add another MAC address the access-list shows up again.  Kinda  weird.  Any reason for this?
Right now you are denying but then allowing the same MAC:
access-list 701 deny   001f.e18a.cf8b   0000.0000.0000
access-list 701 permit 001f.e18a.cf8b   0000.0000.0000
The access list should be the following:
access-list 701 permit 0000.0000.0000   ffff.ffff.ffff
15 Replies 15
Stephen Rodriguez
Evan,
     When you apply the ACL, where are you applying it too?  From the CLI, you cand do a
dot11 association mac-list < ACL number >
this will stop the mac address from being able to associate to the AP.
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
blakekrone
Level 4
Level 4
The link you are following is not going to do what you are looking to do. That link is for creating an association list that only ALLOWS the MACs that you enter, hence the default deny all statement.
This Cisco doc shows in a little more detail how to do the block:
http://www.cisco.com/en/US/docs/wireless/access_point/12.3_7_JA/configuration/guide/s37filt.html#wp1039154
You should be able to reverse the page and change the default action to forward and select block as the MAC action.
Surendra BG
Using the below link may be helpfull..
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008058ed26.shtml#macbasedacls
Here is the deal.. By default u hv the implicit deny on the CISCO IOS (not visible in run config--- enabled by default).. if u explicitly put DENY ANY ANY then the permit statements which comes after that will break the ACL..
Check this bug as well..
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtj83685
So The work around is to not to use IMPLICIT DENY at the end again!!
Lemme know if this answered ur question and please dont forget to rate the usefull posts!!
Surendra
Surendra BG
ZiPPygEEk
@ Stephen Rodriguez
I'm applying it to the Radio0.802.11G interface.
@blackkrone
I followed the link you showed me, which is pretty much the same thing in creating a filter but they add in an extra step where under Security > Advanced Security > Association Access List.  Now when I enabled this I see one or two packets drop, but I'm still able to pass traffic unlike before when it killed everything.  But I still haven't blocked access to the specified MAC I added under the filters.
@SurendraBG
I don't have access to the second link being that I'm a Cisco guest.  I tried simply entering the configuration using just the CLI, but same result as above.  Unable to block that particular MAC address.
ZiPPygEEk
It's back to killing everything again, I'm not sure why it delayed,  but after I configured another Aironet two floors above this one, it all  of a sudden brought my laptop here I'm testing with down.  I find that  very odd.  I really don't understand why this is so complicated, when  its a simple block of a MAC address.
Here is the configuration after following the instructions from the links above.
version 12.4
no service pad
service password-encryption
hostname AP-1stFlrSouthside
no logging console
enable secret 5 $1$y1.u$cgb0SR6.PJcu.04NoiDGB0
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
ip domain name cyberdyne.local
dot11 association mac-list 701
dot11 syslog
dot11 ssid GUEST
   vlan 160
   authentication open
   authentication key-management wpa version 2
   wpa-psk ascii 7 083649420A160812401D0D0A3E2A232D
dot11 ssid Cyberdyne
   vlan 150
   authentication open
   guest-mode
   mbssid guest-mode
   infrastructure-ssid optional
   wpa-psk ascii 7 02570A4D02120E354541074B554643
username Cisco password 7 13094406065F5524
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 150 mode ciphers aes-ccm tkip
encryption vlan 160 mode ciphers aes-ccm tkip
ssid GUEST
ssid Cyberdyne
mbssid
station-role root
l2-filter bridge-group-acl
interface Dot11Radio0.150
encapsulation dot1Q 150 native
no ip route-cache
bridge-group 1
bridge-group 1 input-address-list 701
bridge-group 1 output-address-list 701
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.160
encapsulation dot1Q 160
no ip route-cache
bridge-group 160
bridge-group 160 subscriber-loop-control
bridge-group 160 block-unknown-source
no bridge-group 160 source-learning
no bridge-group 160 unicast-flooding
bridge-group 160 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.150
no ip route-cache
bridge-group 1
interface FastEthernet0.160
no ip route-cache
bridge-group 160
interface BVI1
ip address 192.168.150.21 255.255.255.0
no ip route-cache
ip default-gateway 192.168.150.2
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
bridge 1 route ip
line con 0
exec-timeout 60 0
password 7 031008190B5E2F4D1F
line vty 0 4
exec-timeout 60 0
password 7 111D4A171A43050D55
line vty 5 15
password 7 13114400065D0A2B7A
end
Use the CLI and try this:
access-list 701 allow   0000.0000.0000   ffff.ffff.ffff
That didn't work using access-list 701 permit 0000.0000.0000 ffff.ffff.ffff  I noticed it was placed like this in the config:
ip http server
bridge 1 route ip
blakekrone
Level 4
Level 4
do no access-list 701 deny 0000.0000.0000 ffff.ffff.ffff
ZiPPygEEk
So that last command will revive the connection and get traffic flowing again, but it also allows the restriction on the MAC address I added to pass traffic too.  Does that command cancel out the access-list deny *for that particular MAC* ?  Something is a miss here, very odd.
Can you post the config again with the changes made?
ZiPPygEEk
Sure! I tried with and without the access-list permit.  FYI the allow didn't work, so I needed to use permit.
version 12.4
no service pad
no logging console
aaa new-model
dot11 syslog
dot11 ssid GUEST
   vlan 160
   authentication open
   vlan 150
   authentication open
   guest-mode
   mbssid guest-mode
bridge irb
no ip address
no ip route-cache
ssid GUEST
ssid Cyberdyne
mbssid
station-role root
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 160
no ip address
no ip route-cache
duplex auto
speed auto
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 160
interface BVI1
no ip route-cache
ip http server
bridge 1 route ip
line con 0
exec-timeout 60 0
line vty 0 4
exec-timeout 60 0
line vty 5 15
end
ZiPPygEEk
That was my mistake on the copy and paste.  Now that's very odd, it's  working now.  The MAC address is now timing out, and my other devices  are passing traffic, yet when I make the same setting changes in the GUI  it blocks all traffic.  But it is working!!
So if I want to add other MAC addresses, I noticed it goes underneath the access-list 701 permit.  Will this cause problems? Are access-lists sequential, as in top down?  I don't believe they are, but I want to make sure.
Thank you so much for help  and taking the time to troubleshoot.
When you want to add other MAC address simply do negate the permit statement with a no, add your blocks, then readd the permit.
Glad we could get it working for you, please do rate the posts and mark them as answered as that helps others in the future find answers!
