MAC Address Filtering Autonomous AP 1262
Hello all,
I have an AP1262 (autonomous) with multiple SSIDs, and VLANs.. all of my SSIDs are using WPA-PSK for authentication, but for one of my SSIDs, I also need mac address filtering AND WPA-PSK at the same time...
I know this is possible using a wireless controller..but can I do this with an autonomous AP.. I would also need to do this using the CLI, because its a remote AP, and cant HTTP into it, just telnet..
THanks a Lot
PS: show version
Cisco IOS Software, C1260 Software (AP3G1-K9W7-M), Version 12.4(25d)JA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 09-Dec-10 14:38 by prod_rel_team
ROM: Bootstrap program is C1260 boot loader
BOOTLDR: C1260 Boot Loader (AP3G1-BOOT-M) Version 12.4(23c)JA, RELEASE SOFTWARE (fc3)
1262-A uptime is 6 days, 14 hours, 59 minutes
System image file is "flash:/ap3g1-k9w7-mx.124-25d.JA/ap3g1-k9w7-mx.124-25d.JA"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1262N-A-K9     (PowerPC460exr) processor (revision A0) with 81910K/49152K bytes of memory.
Processor board ID FTX1534E2TA
PowerPC460exr CPU at 666Mhz, revision number 0x18A8
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 70:81:05:51:3B:00
Part Number                          : 73-12175-05
PCA Assembly Number                  : 800-32268-05
PCA Revision Number                  : A0
PCB Serial Number                    : FOC15300WYN
Top Assembly Part Number             : 800-33866-01
Top Assembly Serial Number           : FTX1534E2TA
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1262N-A-K9
Configuration register is 0xF
634
