MAC Address Flapping - Wireless
Philip T Kurien
Friends,
I am having an issue here (not serious i guess).
I have 4 Wisms running on a VSS setup. with 400 APs.
I have been receiving the following logs on the VSS
Sep 12 19:39:10: %MAC_MOVE-SW1_SP-4-NOTIF: Host 001c.bf81.b7bb in vlan 220 is flapping between port Po704 and port Po736
Sep 12 19:39:10: %MAC_MOVE-SW1_SP-4-NOTIF: Host 0024.c454.fac6 in vlan 212 is flapping between port Po735 and port Po736
These are just 2 logs that i have put in, but im getting many more of them.
vlan 220 and 212 are user vlans in the network.
Now, my guess is that they are clients roaming between access points connected to different controllers.
or if Im wrong, is there something serious that i need to look into.
Phil
Stephen Rodriguez
Phil,
     Your guess is correct.  In Wireless, the MAC-Flap notificaiton is 99.999% due to a client roaming between AP on different WLC.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
6 Replies 6
Stephen Rodriguez
Phil,
HTH,
Steve
Thanks Steve,
On further investigation, ive found 90% of the macs showing up are wireless phones or iphones.
So i guess its ok.
Thanks for the help!
Phil
Vinay Sharma
Level 7
Level 7
Hello Philip,
Please mark the Question as Answered, if the provided information by Stephen is correct and it helped. By doing that others can take benefit as well.
Vinay Sharma
Community Manager – Wireless
Thanks & Regards
Hi Vinay Sir, I need your support for wireless issue.
I  getting multiple mac flap error messge in cisco 4507 Core switch while  my mobile clietnts roaming from one AP to another AP due to this my  whole lan network goes down.
And im having cisco AIR-CT2504-K9 controller also.
Requesting you to kindly help me in this case.
dhanraj poojari
Dear Vinay,
 i have the same issues, my network is very simply only2504 controller and one 10 ap when client is moving to  different AP,  i getting the mac flap massage in my switch, please help on  this
Can u tell where your DHCP is configure? if its not on WLC then APs are not getting IP address sometime or your DHCP server become unavailable for a while thus result in MAC flapping. check your DHCP server option in controller TAB of your WLC and verify the IP address. if you have a small number of APs then its better to configure it on WLC
Zain Khan
https://www.linkedin.com/in/forzain/
