05-21-2009 02:05 PM - edited 07-03-2021 05:37 PM
I tried to set MAC filtering with static WEB, my problem is that I can still asociate to the APs even though I delete the mac-address from the list.
The only way I can avoid access to APs with mac filtering is when I associate to other profile and then try again to associate to the profile with mac filtering.
what it could be the problem?
regards
05-27-2009 05:51 AM
You needed to disallow unicast and multicast filters under the radio advanced.
05-27-2009 07:25 AM
thanks for your response.
I have been looking that option in controller 526 but I could not find it in configuration guide file.
Would you be so kind as to telling me where it is?? or which file should I check.
thanks once more
