MAC Filtering on WLANs
Hi everybody.
I want to consult about the MAC Filtering. I've a CISCO 881c...
I've finished all the main configuration of this great router.
This router has two main parts: the ROUTER and the ACCESS-POINT part
Finally, I need to configure the MAC Address security to control the access of who can connect and who can't.
So my configuration is as the following:
ROUTER Part:
ip dhcp pool VLAN20-Informatica
network 191.168.0.224 255.255.255.224
default-router 191.168.0.225
dns-server 190.160.0.13
lease 2
exit
ip dhcp pool VLAN30-Gerencia
network 191.168.0.192 255.255.255.224
default-router 191.168.0.193
lease 5
exit
ip dhcp pool VLAN60-Invitados
network 192.168.60.0 255.255.255.0
default-router 192.168.60.1
exit
ip dhcp excluded-address 191.168.0.225
ip dhcp excluded-address 191.168.0.193
ip dhcp excluded-address 192.168.60.1
interface FastEthernet0
switchport access vlan 20
no ip address
exit
interface FastEthernet1
switchport access vlan 30
no ip address
exit
interface FastEthernet2
switchport access vlan 60
no ip address
exit
interface FastEthernet4
ip address dhcp
ip nat outside
exit
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
no ip address
exit
interface Vlan1
ip address 191.168.1.1 255.255.255.252
exit
interface Vlan20
ip address 191.168.0.225 255.255.255.224
ip nat inside
exit
interface Vlan30
ip address 191.168.0.193 255.255.255.224
ip nat inside
exit
interface Vlan60
ip address 192.168.60.1 255.255.255.0
ip nat inside
exit
ip nat inside source list LANs-TO-INTERNET interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip access-list standard LANs-TO-INTERNET
permit 191.168.0.224 0.0.0.31
permit 191.168.0.192 0.0.0.31
permit 192.168.60.0 0.0.0.255
AP Part:
dot11 association mac-list 700
dot11 vlan-name Informatica vlan 20
dot11 vlan-name Gerencia vlan 30
dot11 vlan-name Invitados vlan 60
dot11 ssid Informatica
   vlan 20
   authentication open
   authentication key-management wpa
   guest-mode
   mbssid guest-mode
   wpa-psk ascii 0 maforinfor
   exit
dot11 ssid Gerencia
   vlan 30
   authentication open
   mbssid guest-mode
   wpa-psk ascii 0 maforgeren
   exit
dot11 ssid Invitados
   vlan 60
   authentication open
   mbssid guest-mode
   wpa-psk ascii 0 maforinvi
   exit
interface Dot11Radio0
no ip address
encryption vlan 20 mode ciphers tkip
encryption vlan 30 mode ciphers tkip
encryption vlan 60 mode ciphers tkip
ssid Gerencia
ssid Informatica
ssid Invitados
ssid Planta
ssid Usuarios
mbssid
exit
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
exit
interface Dot11Radio0.20
encapsulation dot1Q 20
no ip route-cache
bridge-group 20
bridge-group 20 subscriber-loop-control
bridge-group 20 block-unknown-source
no bridge-group 20 source-learning
no bridge-group 20 unicast-flooding
bridge-group 20 spanning-disabled
exit
interface Dot11Radio0.30
encapsulation dot1Q 30
no ip route-cache
bridge-group 30
bridge-group 30 subscriber-loop-control
bridge-group 30 block-unknown-source
no bridge-group 30 source-learning
no bridge-group 30 unicast-flooding
exit
interface Dot11Radio0.60
encapsulation dot1Q 60
no ip route-cache
bridge-group 60
bridge-group 60 subscriber-loop-control
bridge-group 60 block-unknown-source
no bridge-group 60 source-learning
no bridge-group 60 unicast-flooding
bridge-group 60 spanning-disabled
exit
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
exit
interface GigabitEthernet0.1
bridge-group 1
exit
interface GigabitEthernet0.20
bridge-group 20
exit
interface GigabitEthernet0.30
bridge-group 30
bridge-group 30 spanning-disabled
exit
interface GigabitEthernet0.60
no ip route-cache
bridge-group 60
interface BVI1
ip address 191.168.1.2 255.255.255.252
exit
ip default-gateway 191.168.1.1
access-list 700 deny   0000.0000.0000   0000.0000.0000
access-list 700 permit 9803.d860.b50d   0000.0000.0000
access-list 700 permit 001b.11b1.c553   0000.0000.0000
This configuration work great.
All host of the wired side and the wireless side can access to internet flawlessly.
In the AP side I can filter (deny) the access of all wireless devices
In the AP side I can grant the access of two devices ( 9803.d860.b50d - 001b.11b1.c553 )
The problem is here:
I need to grant the access to any wireless host that try to connect to " Invitados " SSID ( VLAN 60 )
The problem is that the [ dot11 association mac-list 700 ] sentence affect to the main antenna [ dot11Radio 0 ]
So all devices are filtered included the Invitados SSID ( VLAN60 )
All I need is to filter only the Informatica SSID and Gerencia SSID (VLAN20 AND VLAN30)
The VLAN60 I want that to grant all access to any device.
I hope that anybody can help me.
Thanks!
1 REPLY
VIP Purple
Hi Alfredo,
Configuring MAC Filtering:
By GUI:
click Wireless > MAC Filter to open the Wireless - MAC Filter page, enabling you to restrict access to specific SSIDs according to device MAC addresses.
For each SSID, you can specify MAC addresses to allow or MAC addresses to deny. By default, the MAC restriction feature is disabled for all SSIDs.
Complete the following steps to configure MAC filtering for an SSID:
Step 1 In the Select SSID drop-down list, select the SSID to configure.
Step 2 To add a MAC address to the list, click Add and enter the address.
Step 3 To remove a MAC address from the list, select the "Remove" check box for the address and click Remove.
Step 4 Select a MAC restriction mode:
  • Disabled—The feature is disabled.
  • Allow—Allow devices with the specified MAC addresses to connect.
  • Deny—Do not allow devices with the specified MAC addresses to connect.
Please also check this link to configure mac filtering in both ways GUI and CLI
http://www.cisco.com/en/US/docs/routers/access/800/860-880-890/software/configuration/guide/config_WLAN.html#wp1251791
Dont forget to rate helpful posts.
461
作成コンテンツを作成するには してください
