03-13-2006 08:00 PM - edited 07-04-2021 11:46 AM
I have a few Macs that I can only use WPA2 Personal with against a 1131. I setup the Accesspoint as the RADIUS server, but I see nothing in the log files. WPA2 Personal works fine, but I don't want to use Open authentication.
I set it up exactly as per Cisco's documentation.
03-17-2006 01:32 PM
This is surely a configuration issue. Have a look at this document which explains how to configure the AP for WPA 2. Using this documentation reconfigure this setup and check if it works.
03-19-2006 08:25 PM
This IS the document I started with, set it up identical, no connections, nothing even in the log file. Switched to WPA2 Personal all macs worked fine. I thought it's probably configuration too, but after following the setup instructions, and troubleshooting, I'm not so sure.
I'll try to troubleshoot some more and post here the results.
03-23-2006 01:07 PM
How's your Mac's "Internet Connect" set up?
04-20-2006 11:21 AM
The Macs have been setup manually for Wireless access through the Access-point (no DHCP), no proxy, etc.
The connection via WPA2 Personal works fine, I think it's just a problem using RADIUS.
05-16-2006 02:34 PM
I agree with yjdabear, you need to use "Internet Connect" to do the RADIUS part of the configuration.
05-16-2006 05:36 PM
Matthias,
Maybe you could tell me where I can find the setup for Radius in Internet Connect? I set it up as per the document but remember I am using the Mac utilities for the Airport, not the Cisco client.
If you can show or tell me the exact Mac config that differs at all from that Cisco document, that would be great.
Cheers
05-30-2006 12:23 PM
I don't know if you still need this, but if you open internet connect and then go to File -> New 802.1x connection, then it will give a place to set it up. Let me know if you need any other help.
05-30-2006 12:28 PM
05-30-2006 06:14 PM
I will give it another try...
