Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Macintosh clients prompted for WEP key when there is none.
We have several Mac clients in the same location who cannot connect to our wireless SSID. This SSID has no security enabled (we use a VPN for that), yet these Macintosh clients are prompted for a WEP password when they try to connect.
Windows systems in the same physical location do no have any problems when connecting to the same SSID.
Initially we suspected a problem with the upgrade to OS X 10.5.5, but we then tested with an earlier OS, 10.4.11, and had the same results.
Mac clients in other locations on campus [connecting to APs that are on the very same controller as those in the problem area] do not have this problem.
I don't know where to go next; TAC says it must be an Apple client issue but clients using the exact same OS version elsewhere on campus do not have this problem. How weird is this!
Any suggestions welcomed.
1 REPLY
Silver
Re: Macintosh clients prompted for WEP key when there is none.
The service set identifier (SSID) identifies the wireless network that you want to access. Range: Up to 32 characters (case sensitive) But make sure that If you leave this parameter blank, your client adapter can associate to any access point on the network that is configured to allow broadcast. If the access points with which you wish to communicate are not configured to allow broadcast SSIDs, the value of this parameter must match the SSID of the access points. Otherwise, you will not be able to access the network.
157
